Just got done replacing oil pump, chain, tensioner, oil pickup tube, cam chains in the back, oil filter housing/oil cooler gaskets after encountering low oil pressure. After doing the change, the pressure is now reading within specs (around 60psi cold, hovers around 30-40psi at operating temperatures) however there appears to be no oil making it to the cylinder head. I can hear valve ticking and when I removed the valve cover, the cams were nearly bone dry.
I did some searching on this and various forums and am not sure what the culprit might be. When I checked the oil passages there wasn't any obstructions that I could see. I have been searching and I haven't been able to find any oil relief valves that could be causing the issue (looking through the various diagrams) ONE thing that comes to mind is the oil filter housing which, while I was viewing it, one of the two valves(?) was stuck closed as much as I tried to push it. Maybe that could be the issue, not sure.
Anything else I should be checking? Did a decent amount of work on this car and I'm not ready to give up yet.
