Results 1 to 9 of 9
    May 11 2023
    South Africa
    A4 B9 FWD to Quattro?
    Hey guys,
    I have a B8.5 S5 3.0T and really happy with the car. I recently bought a FWD B9 A4 2.0T, and really miss the quattro when driving this car.
    Has anyone done a quattro retrofit? There are plenty of cars out there stripping for spares - just wondering what the extent of the work would be?
    Thanks in advance
    Jul 16 2018
    Atlanta
    Transmission, drive shaft, rear subframe, rear axles, rear wheel bearing housings, probably some changes in springs/dampers. I guess it's viable, but is it really worth it over just swapping for a quattro build (assuming you find an early one with real quattro and not that quattro ultra junk).
    May 11 2023
    South Africa
    thanks, one question - why would the transmission have to be swopped? I was sort of anticipating all the rest (everything behind the transmission, plus rear differential), which could probably come from a donor car for a decent price
    Jul 16 2018
    Atlanta
    FWD transmission is not going to have the output to the rear. You probably have a DL382-7F aka type 0CK, which has only FWD output. You're going to need a DL382-7Q aka type 0CL, which has a Torsen center diff and rearward output. I don't advise the DL382-7A aka type 0CJ, which has quattro ultra AWD clutch and rearward output, if you can get a real Torsen solution. But I guess it's still better than FWD. The rear diff is not the same for the Torsen center diff vs the quattro ultra AWD clutch. The DL382 is the second gen DCT, replacing the first gen DL501 you probably had in the B8.5 S5. But the B9 S models get the ZF 8-speed rather than the DCT.
    May 11 2023
    South Africa
    Thank you - this helps, will start doing my homework
    Aug 04 2014
    Orlando FL
    Any progress with this? I have a front damaged Quattro A4 b9 entirely for parts and I want to do this same conversion on a FWD A4 B9, same year on both cars. I have every part available to do the conversion and obdeleven/rosstech as well. All tools you can imagine as I own a full size shop. To the programming experts, what would it take to make the ECU control the system? Is there any wiring difference?
    Jul 18 2022
    I have to ask, would it not be less work to swap the engines (assuming the damaged vehicle doesn't run) and then repair whatever body damage exists using the FWD car?
    Aug 04 2014
    Orlando FL
    Donor vehicle has a salvage title Vs clean on the FWD
    Established Member Two Rings SkillzVrt's Avatar
    May 03 2012
    Carson, CA
    Quote Originally Posted by hcvdberg1253 View Post
    Hey guys,
    Thanks in advance
    Honestly not worth it all especially when there is a vehicle out there already with a quattro system already equipped. It would be different if your doing like a GTI and converting it to AWD, fun project and unique.
