Results 1 to 9 of 9
    Nov 25 2023
    2000 Toyota Tundra
    Tucson, AZ
    Weird issue with cold starts
    I have a 2023 RS3 about 3 times now when I start the car, it idles very rough like it is misfiring and I get a drive malfunction message. I immediately shut the car off and after waiting a few minutes fire it up again, warning message is gone and it’s back to idling like normal.
    Has anyone else experienced this before?
    Veteran Member Three Rings 993140's Avatar
    Oct 14 2012
    GT3 Touring
    Way Out West
    Quote Originally Posted by WallopingTuba View Post
    I have a 2023 RS3 about 3 times now when I start the car, it idles very rough like it is misfiring and I get a drive malfunction message. I immediately shut the car off and after waiting a few minutes fire it up again, warning message is gone and it’s back to idling like normal. Has anyone else experienced this before?
    Yes, I have a 2024 with ~4700 miles and this happened only once quite a long time ago. I didn't think much of it since no permanent message was displayed. I just keep driving it now...
    Viken
    2024 RS3
    2023 S3 Premium Plus
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Look for S3DUDE on here, he’s had some issues, I believe it was battery related.
    Apr 25 2017
    MKV R32, 17 GTI, 12 Turbo Beetle
    Marietta GA
    Scan it? ECU should report on that.
    Mar 09 2018
    2018 RS3
    I'm sure there is a code stored if there was a drive system malfunction. Scan it with VCDS/obd11 or bring it to the dealer.
    Florett RS3+DS1+034TCU
    Senior Member Three Rings NapalmEnema's Avatar
    Jul 02 2022
    2022 Kyalami Green RS3
    Houston
    Never happened here - 2022 RS3
    2022 RS3 Kyalami Green
    2017 M2 Performance Edition - Arctic White
    2021 Type R - Shadow Grey Pearl
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I had a ton of issues with the starting. They finally just released a TSB 5 weeks ago addressing the issue for good. If you haven't had your car reflashed at Chapman Audi you will probably benefit from the TSB, it is an issue only on the 8Y. What color is your RS3? I probably have seen you around in town.
    Here are my problems and fixed to the starting issues:
    https://www.audizine.com/forum/showt...update)-Part-3
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Nov 25 2023
    2000 Toyota Tundra
    Tucson, AZ
    Quote Originally Posted by S3DUDE View Post
    Heyo! Thanks for info and I actually came across your posts, did you ever experience a rough idle to as if it was misfiring? I was planning on running over to Chapman on my next day off.
    Mine is kayalami green there is another one running around town too.
    Aug 29 2017
    Tucson, AZ
    Kyalami green there is the one that we own which is driven by my wife 99%, then there is another Kyalami green fully loaded ordered by a lady before us. I believe the lady ordered hers on Sep 14th of 2022 because we were third in line and she was second but ironically we got ours in October of 2022 which was at least about a year before they got theirs, the reason why is because we were offered four RS3 to pick from that were already built in the summer of 2022 (two blacks , a white and the Kyalami).
    If you need a third party shop to do your maintenance and mods I would recommend independent VW/Audi shop on 22nd, it is a specialized VW/Audi shop next to the Nissan dealer. For warranty issues take it to Chapman off course.
    at 3100ft elevation
