Results 1 to 6 of 6
    Junior Member Two Rings
    Sep 26 2014
    Sweden
    Rear subframe differences Avant Quattro?
    My rear subframe on the Allroad is rotten.. so It needs to be replaced (it looks to far gone to justify the time for a repair)
    In ETKA the allroad shares the part number with the regular A5/S4 and A5/S5 quattro, 8K0505235AK. The A4 and A5 however also has a version with an H instead of a K at the end.
    Do I need to find a part with the ending K or will the H fit just as well?
    In short: Should any B8 quattro rear subframe fit?
    Jul 16 2018
    Atlanta
    B8 A4 allroad rear subframe, p/n 8K0 505 235
    AF through Apr '09
    AG through Sep '09
    AJ through Aug '10
    AK through Sep '15
    AN for Oct & Nov '15
    AQ starting Dec '15
    B8.0 A4 quattro rear subframe, p/n 8K0 505 235
    L > AB > AH > AP > AQ - A4, A5 with 4-cyl
    AD > AF > AG > AJ > AK > AN > AQ - S4, A5 with 6-cyl, S5, sportback
    AH/AP had 8K0 505 145 B front and 8K0 505 145 C rear bushings
    AK had 4G0 505 145 B front and 4G0 505 145 C (hydro) rear bushings
    AN had 4G0 505 145 G front and 4G0 505 145 C (hydro) rear bushings
    AQ has the same bushings as AN
    So you should stick to the AK > AN > AQ line. The AH > AP line is clearly meant for lower stress/load builds. That AN only lasted two months before being replaced by AQ, no idea what to read from that.
    Sep 26 2014
    Sweden
    Thank you! That helps alot :) Basicly any A4 allroad or other B8 with 6 cylinder engine then :)
    Sep 26 2014
    Sweden
    Or which ever and just replace the bushings if they are the only difference?
    Jul 16 2018
    Atlanta
    I don't know if the AK/AN/AQ bushing set would be exchangeable into the AH/AP frame. Could be a direct swap, could be different (such as 65mm conventional vs 75mm hydraulic for the front guide links). And I don't know if the AH/AP, being targeted for lower load vehicles, wouldn't be built to lower capabilities (cheaper part for mass manufacturing volumes).
    Jun 11 2023
    Dunwoody GA
    Lifetime Audi parts had these for cheap if you are anywhere close to North Carolina. Can also be had on eBay.
    2015 S6 | RS7 Turbos | RS7 Intake | JHM Goodies | Kyletunedit TCU | DS1 Stage 3 | 034 mounts |
    2015 Q7 TDI P+ | Child seat | Crumbs |
    2014 A4 P+ S-Line | OEM+ | K04-064 | RS5 sway bars | Sport suspension swap | CR15 | Meyle HD everything | Q5 Brembos | Akebono ceramic pads | S4 Petals | A6 TDI intercooler | R8 coilpacks |
    1984 GTI | 07K swap | because race car |
    1981 Scirocco S | 07K swap | because street car |
