Results 1 to 8 of 8
    May 08 2024
    A7 C7 3.0t 2012 oil leak
    Hello guys, my first post here.
    I have been fighthing an oil lrak on my c7 a7.
    It was pretty obvious the main source of the leak was the oil filter housing, i changed that and fully cleanned my engine bay.
    It was dry for months. No oil drips
    This morning i had the little drops of oil on my parking spot.
    I still didnt had a chance to lift the car and fully inspect the bottom of the car, but the top of my engine bay is pretty clean and dry.
    Would love to hear from other users what are the most comum causes of oil leak on c7 3.0t engines and what to attack next.
    I will try to get an oil change tomorrow and ask then to perform a visual inspection for leaks. I will update here.
    Thanks.
    Junior Member One Ring
    Feb 16 2024
    Oahu hawaii
    Rear main seal?
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Quote Originally Posted by Bk808a6 View Post
    Rear main seal?
    RMS, upper timing covers (outer corners) and lower timing cover (lots of orings) are all suspect. There's a lot of possibilities. If your belly pans are in place it could be traveling as well leading you to look at the wrong suspects.
    You can buy some Rhino Ramps and crawl under and do regular inspections after cleanings rather than trust someone else's eyes. Leave the belly pans off for a drive and then recheck.
    Cheers!
    KS
    May 08 2024
    Rear main seal?
    Yeah i will do this next.
    May 08 2024
    Quote Originally Posted by Botbasher View Post
    Cheers!
    KS
    Thanks. I live in a condo. No garage, just a parking spot. I will take it for a wash and see if i can find the leak with the ramps. Thanks for the tips.
    Sep 16 2020
    West Michigan
    Oil cooler and vacuum pump were both leaking on my 3.0t.
    Replaced the vacuum pump + gasket eliminated that one and a new oil cooler gasket + new screws (factory are 1 use aluminum and tend to snap off) remedied my oil leaks.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jul 26 2018
    Humidity, NC
    Quote Originally Posted by sepheroth86 View Post
    Vac pump is up high on the front of the motor and the oil cooler is down low on the drivers side. That trail should be easy to see if it's either of those.
    But while you check the oil cooler, inspect the hi/low oil pressure valve, just to the rear of the oil cooler. The oring on it is another insidious leaker and VERY difficult to access.
    All 3 of these are towards the from of the motor and should leave copious evidence on the belly plates!
    Cheers,
    KS
    Nov 30 2023
    Munich
    Oil leaks on C7 3.0t engines often happen because of valve cover gaskets, oil pan gaskets, or oil cooler seals. Look for oil around the turbocharger oil lines too. Check the PCV valve and hoses, as they can also cause leaks. And inspect the valve cover gaskets.
