Results 1 to 7 of 7
    Veteran Member Three Rings LawDawg's Avatar
    Feb 20 2008
    Naperville, IL
    Air suspension fault; Replacing level sensor help
    I’m getting a air suspension fault from time to time and when it happens, I get the really harsh ride that everyone refers to. The code is:
    455692 - Sensor for Ride-Height
    C1048 07 - Mechanical Failure
    Intermittent
    From the digging that I have done on the Internet. It looks like this is a faulty front left (driver’s side) sensor. I’ve ordered a new Arnott replacement sensor from FCP.
    Is there anything I should know before replacing this? If I disconnect the battery before the replacement, do I still need to recalibrate? After I recalibrate if I need to, do I then have to follow that up with additional recalibration for either the headlights or the camera system? Or is recalibration limited to simply string the new ride height?
    Finally, it looks like the front sensors are pretty straightforward to replace. Thank God it wasn’t one of the rears. Anything tricky about the job?
    Thanks for any input!
    Junior Member One Ring
    Jan 28 2024
    Cali
    Very easy
    Jan 28 2024
    Cali
    Not even really necessary to recalibrate unless your suspension height is not looking normal after. But calibration is easy if u follow the youtube video on it.
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Quote Originally Posted by 1sickc7 View Post
    Easy... but do not hit the button "RESET ALL ADAPTATIONS"!!!! You effectively brick your air suspension module and you'll have to get Audi to reset it!
    Several have had this happen recently, so be aware and be careful!!
    Cheers,
    KS
    Jan 10 2017
    CA
    Hi all -- been a while since I've been around here. I had the air suspension system fault pop up this morning.
    455691 (not 692 like above) and c1048 07 - mechanical failure.
    So I'm assuming easy peasy replacement of the sensor, but I physically inspected all 4 and there is not anything obviously wrong with any of them. Any ideas from the group on anything specific to look for? Otherwise, I'll just replace both of the fronts and see if that fixes it and if not, move on to the rears.
    I wish the code identified which one was the culprit (maybe that is in the 455691 vs 455692, but google wasn't much help sorting that out and from other posts I've seen both codes).
    Thanks in advance to any suggestions
    2016 Daytona Gray S7. Black optics + sport pkg. Stage 3, eurocode stuff, cosmetic stuff.
    Jul 26 2018
    Humidity, NC
    Quote Originally Posted by kpriv View Post
    Did you do anything on a lift or ramps??
    I worked on the suspension and as soon as I let the car down these faults popped up. Reset them and all was good. More work... more codes.
    Finally put together that the car was loading the suspension and e-brake was holding it higher than it expected when I lowered it to ride height!.
    Undo the e-brake first and never had it happen again. Sometimes it's an order process!!
    Cheers!!
    KS
    Jan 10 2017
    CA
    Good question and appreciate the response but nope - haven't done anything recently. I ordered the replacement pair for the front but as a hail mary before swapping them I might lift the car up and add a spray of white lithium in each of the ball joints. Long shot, but maybe one of them momentarily stuck and the car freaked out.
