Hi folks, i just changed brake pads end of last year, and recently brake nosie is driving me crazy.
looks like the iron rotors life is coming to an end at 60,000 km.
i can see the edge of the rotor has a higher than the portion of the rotor which is contacting brake pad.
I was exploring the options of brake rotor replacement and found the following options:
1. Brembo OE parts with 09.D481.43 for front 420mm iron rotor and 09.D482.33 for rear
but unfortunitely those parts are only seling in EU, but not here in canada
2. In another thread i see MtnRinger mentioned 2022 Cayenne Turbo S e-Hybrid has same 420mm front rotor that might be the same size.
i see a set is selling for CA$1,487.49 looks like a pretty good deal here, but is there anyone can confirm if the fitment are the same for audis and porsches? also if the rear one are the same size as well?
https://www.crossdrilledrotors.ca/po...02127da-k.html
ref: https://www.audizine.com/forum/showt...1#post15049934
3. Factory rotors, most expensive option here
is there anyone going thru this, please help here.
