Results 1 to 11 of 11
    Junior Member Two Rings K_RedLazer_24's Avatar
    Apr 24 2022
    '17 GMC Terrain (dad mobile) '00 Audi b5 s4
    Lewisburg, Pa
    Impossible to find Piston oil spray jets (oil squirters)
    So upon tear down I found a peice of metal tubing in my lower oil pan maybe 1/4" in length if that. Once I fished it out of the remaining oil and cleaned it up I realized it was the tip of one of the oil spraying jet a.k.a oil squirters. I'm not sure how that could have got broke of especially since the bottom end has the stock pistons, on I.E rods that are standard length. I've searched high and low for answers to no avail. My only guess would be a piston skirt some how hit and snapped it off, even though I put a few thousand miles of the car with this bottom end set up and never had an issue. Now I'm looking for a replacement and I quite literally can find ever style squirter for every other motor but not the one I need for the 2.7t. Aside from disassembling a motor at salvage yard to find one is there a company that sells them or a upgraded solution or any solution to this problem. Another concern is it possibly happening again and what can be done to ensure it doesn't happen again. Thank you for any and all input, advice, two cents, what ever information you share to help solve this issue.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    If you’re really in a pinch, I have a set in my engine coffee table.
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    078103158C is the P/N
    Looks like JHM website lists some in stock?
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by PwrWgn View Post
    I’d call them since they are NLA and JHM isn’t good with updating their site.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    I have some used ones from motor builds if, you are still looking for some.
    Apr 24 2022
    Lewisburg, Pa
    Thank you PwrWgn and Silverex for the P/N, and heads up on calling them I literally just placed an order earlier this week at JHM and had to call them so looks like I'll be giving them another call and possibly another order haha
    CELison I appreciate you willing to take bits from the greatest coffee table ever. I always wanted to do a engine coffee table after I did an little s.o.h.c Honda motor end stand. Wish I still had that but life, wife, kids etc I ended up selling it.
    Apr 24 2022
    Lewisburg, Pa
    Xalents23 I may need those if JHM is out of stock or can't get them back in stock in a decent time. I'll let you know what's up for sure thank you
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    I did a quick search for part 078103158C, and they are listed at Modded Euros at https://www.moddedeuros.com/products...jet-078103158c but I'm not sure if they actually can have or can get the parts. I've ordered some CV joint gaskets from that company, and the transaction went fine.
    - Jim
    May 10 2018
    MA
    Quote Originally Posted by Calif_Kid View Post
    - Jim
    They don’t have them, nor will be able to get them.
    Tons of sites do this, and you end up wasting the only to get a cancellation notice
    Apr 24 2022
    Lewisburg, Pa
    Apparently these are truly impossible to acquire anymore. Sounds like my best chance would be to purchase a set of jets from someone here or local salvage. That being said the "check valve" for these are in the bolt correct, not in the tubing its self? If I'm gonna get a set I might as well check that the valve works properly and replace if needed.
    Oct 26 2011
    CA
    Here are my spare OEM Audi B5 S4 oil squirters I have. Let me know if you still want to buy them. I just ran some brake clean through them and they all have great flow. They are straight and not bent. Can have them shipped out with tracking on Monday let me know.
    Audi B5 S$ OEM Oil Squirters Top by PHU DO, on Flickr
    Audi B5 S4 OEM Oil Squirters Bottom by PHU DO, on Flickr
