so as some of you know I've had a highly intermittent fueling problem in my car. I don't drive it a ton, but every year or so the car just died and won't restart,, leave it an hour and it will restart fine and you are good for another year ...
well last time it happened I got it to set a code, fuel pump, mechanical failure. so it restarted eventualy and it's been good for the last year. but I did manage to score a pump assembly a month ago at a good price from a wrecked car. fast forward to today
I had nothing going on so decided I would look at the pump . that ring is a total pig to get off, even if you have the right tool it's still a pain. so I just use a flat blade screwdriver and a hammer. after an hour I got it go move about I inch . I thought okay . I have it moving. I will leave it at that as I still have half a tank. I will wait till it's almost empty. buggered up a lot of the ring and will likely need to order a new one and a seal anyway
so tonight at about 630 I decided to go see my buddies and took the Audi to start using some gas. I made it about a km from my house and it straight died could not restart it. so whatever was Intermittent I had now completely broken in the fuel pump. not to worry .
I thought well now my car is on the street off to the side, no danger but I can't leave it there overnight
so I ran home , got my pump, a hammer , screwdriver, a few rags. fortunately the back seat was out.
buggered around for another hour sweating and straining but got the ring to release .. great . started to undo it and sure enough gas started pouring out .... damn . quickly did it back up .
ran home got an empty gas container some hose and a hand pump I have. fortunately with wrenching for 40 years there isn't many tools I don't have.
got about 3 gallons out before trying to do the ring again this time it unscrewed without spilling gas.
I started to pull up the pump and saw the problem immediately . the filter had become detached from the pump assembly and was floating free. had probably become detached from me hammering on the ring. I clipped it back and it was solid there was no way I detached this from the pump by hammering the ring this was never attached properly right from the factory. this has been the problem all along occasionally pulling air, more on that later.. so I decided to put my replacement assembly in anyway as it has 100,000 less km on it.
fired up with what little battery power I had left after the car trying to start the car previously
more work to do but I am running and got the car home. ring isn't completely tight because I have to go back in and need some help
there was a wiring harness that ran Into the tank with a clip on it to keep it secure to the assembly, I took it off the old one by reaching around but wasn't sure exactly how it clipped in, if someone knows that would be great. I was running out of light so had to just get the car home and left it dangling in the tank. when I got the car home, I could see gas was pouring out ( ring was 1/4 turn from being in its original location) ..moved it another inch and leaking apears to have stopped.
current plan is to run the tank empty, find out where the harness clips, and fix that, then put it back together with a new ring and seal.
quite the 90 minute adventure.
so when I got the car home, I tried for the life of me to "unclip" the filter the way I found it in the tank, no friggen way, you would need two flat blade screwdrivers and 3 hands I am 1000% sure that was not installed properly from the factory.
has to be one of my better road side fixes. lol
allmost got it tucked in enough. too close to leave overnight for my comfort level.
Sent from my SM-G973W using Audizine Forum mobile app
