Oh, control circuit, that's completely different than the sensor.
The F22 is the same for B8.0 and B8.5. It was 06E919081C, gray, through Jan '14. Then it was changed to 06E919081G, violet. The gray remains the R&R for the 3.2L CAL, but the violet is the R&R for the 3.0T non-CRE. They are not identical trigger spec. Gray is 2.5-3.2 bar; violet is 2.3-2.8 bar. But electrically, they are interchangeable. The change date seems to relate to a TSB on the subject:
https://static.nhtsa.gov/odi/tsbs/20...65437-2280.pdf What's wrong with the gray, no idea.
Apparently, 06E919081D is also a 2-pin gray, but that's a F378 switch (0.75-1.05 bar) for the CRE engine.
Ok, so the visual confirmation is the white/gray from the J519 and the brown to the engine harness ground circuit (131) were shorted together. If any damage was done, I'd expect it to be to the J519 circuit for the F22.
So to the flap control solenoid, the N316. There's a flap position sensor on each bank, one for each flap runner. But there's just one activation solenoid for passing the vacuum to the actuators. N316 is powered direct by 12v from the fuse 5 in the ECM box, and selectively grounded by the ECM. Violet/white wire from N316 pin 1 to J623 T60/36.
But the question becomes what's the actual problem with the flap activation.
P2010
Intake Manifold Runner Control Circuit High Bank 1
Intake Manifold Runner Control Circuit / Shorted to B+ Bank 1
• signal current > X amps for at least 2 seconds
Interestingly, MY10 has P2010 triggered by > 1 amp, but MY11 and MY12 are > 2 amp. Guess they were getting too many false concerns.
But so how does P2010 occur? The ECM grounds T60/36 and sees more than 1 amp of current flow.
If you measure the resistance reading across the N316 solenoid from pin 2 to pin 1, what does it read? If there's always 12v on pin 2, then as soon as the ECM grounds pin 1, V/R = I is going to happen.
Wonder if that violet/white wire from the J623 to the N316 is shorted in the harness to the gray/white from the J519 to the F22.
