Looking for any help or insight... really struggling to resolve my misfire issue.
I've had a misfire on cylinder 3 for 2 months. After the car sits overnight... it stumbles to start a little, then has rough idle, but it clears up after a minute of warming up. Always only cylinder 3. I figured it was a leaking SC intercooler, as I swapped coils and plugs without any success.
So I decided to tear into the engine, and do intercoolers, PCV, tstat and waterpump... and carbon cleaning. Cylinder three definitely had coolant leaking in for some time. It was bar far the worst. I also installed new valve cover gaskets as I had some oil in the spark plug tunnels.
I finished all the work, pulled and checked injectors as well... and put them back at random cylinders.
But now the car misfires on cylinder 3 all the time, and it seems worse.
Cylinder 3 pressure is above 150 as well.
Coils replaced, plugs replaced, injectors cleaned and installed at different cylinders, all valves carbon cleaned, PCV replaced. .... So what else could still be causing P0303 and rough idle???
