Results 1 to 7 of 7
    Mar 18 2024
    Omaha, NE
    Does the fuel cap normally click?
    I recently bought a used 2012 A6, and a CEL appeared shortly after with code P0456 for a small EVAP leak.
    In the course of checking everything that would normally cause the fault, I was checking the fuel cap and realized that although it states "Tighten Until One Click", mine never actually "clicks", it just stops turning and then sort of springs back 1/8 of a turn or so. It feels tight and I had never given it any thought until now, so the question I am wondering is, does this fuel cap normally "click" or is what I have described the normal function of this cap?
    I would love if I could resolve this code with a new fuel cap, but don't to waste $60 if the cap I have is fine. Thanks!
    Veteran Member Four Rings ENV²'s Avatar
    Nov 04 2010
    They don’t click like the old ones but the cap gasket might be an issue.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    May 20 2010
    Mine clicks once I believe; agree with the gasket probably being the issue.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Nov 12 2015
    Oregon
    Turn it until it "clicks". It kinda has a position like an ignition switch does. Closed and then CLOSED with a partial click.
    Sent from my SM-N960U1 using Tapatalk
    My build log
    Mar 18 2024
    Omaha, NE
    Quote Originally Posted by VinnysS4 View Post
    Thanks. That’s a perfect description of how mine is. So it seems that is it’s normal function.
    Nov 12 2015
    Oregon
    Quote Originally Posted by sdhildebrand View Post
    Absolutely. Yeah it sounds normal. I would check the seal on the cap to see how it looks. Other than that, a smoke test is really the only way to narrow it down . If you have a big boy scanner you can do a purge and seal test to see if the tank holds pressure. If it doesn't, you likely have either a bad cap or a stuck open purge valve or Leak detection pump leak.
    My build log
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Clean the sealing area of the cap and filler neck and see if that makes it go away. If not then probably a new cap is needed.
    You can get a cap off Amazon for under $20.
