need new summer rims. I have found a very nice set of used forged rims and am trying to get a consensus on the fit. My main concern is suspension clearance*
with the 10.5 inch rim. the offset is ET30. I would run a 295/40/21 tire. without spacers according to Willtheyfit.com website the wheel will be 11.7 mm closer to*
suspension and poke out 13.7mm. After looking at suspension I think the 11.7mm closer to suspension is an issue. So thinking a 5mm spacer would put me at
6.7mm and 18.7mm. I think the poke will look good, can anyone confirm no rub issues with the Q7 in Dynamic mode with 295 tires. Does anyone know if a*
reduction of 6.7mm will be a issue on the suspension, there is not alot of room in there.*
Appreciate any comments thank you
Mike
