Results 1 to 3 of 3
    Junior Member Two Rings
    Sep 10 2022
    Australia
    Audi a4 b8.5 headlight pin/wire diagram help
    Hi guys, does anyone have the headlight pin/wire diagram for audi a4 b8.5 bi xenon headlight. Ive been looking everywhere and i could not find anything. Im doing some custom lighting and i need to know which wires is which. The connector has 14pins.
    Photos of the headlight and the connector:
    https://drive.google.com/drive/folde...2-a095pUJ_BN1r
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    You should try searching for the answer...
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Jul 16 2018
    Atlanta
    There's two different wiring configs, depending on if you have cornering or not. section 122 of the B8 A4 wiring diagrams covers B8.5 for HID; section 123 of the B8 A4 wiring diagrams covers B8.5 for HID+AFS (cornering). You can find the wiring diagrams in places around; cardiagn.com has them.
    6 is the HID bulb, 9 is the turn signal, 10 and 12 are the DRL; that's the same for both headlamp configs
