Results 1 to 6 of 6
    Junior Member One Ring
    Aug 01 2023
    Connecticut
    B9 s4 upgraded charge pipes a necessity with upgraded intercooler?
    Hi all, looking to get a quote on upgrading to IE's non-sport intercooler and shop is asking if I wanted to upgrade the charge pipes as well. Not too familiar with car parts yet and was wondering if it's something I should consider a necessity to get done or not? I'm just trying to not get ripped off lol, thanks in advance!
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    I'd say only if you are running much higher boost like a stage 3 type setup. Otherwise the charge pipes won't make much of a difference.
    Aug 01 2023
    Connecticut
    Only planning to go stage 1 for reliability reasons, thanks for the advice!
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    Definitely not required. For stage 1 & 2; an IC + tune is worth it in any climate, high flow cat for stage 2 obv, and that's all you need on pump gas. I've run the same times with and without anything else, it's just not necessary until you're on a bigger turbo.
    An intercooler + pump gas tune is all 95% of buyers will ever need, and you can spend the rest on suspension bits and wheels!
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    Senior Member Four Rings
    Nov 20 2021
    United Kingdom
    I honestly don?t think they?re even a necessity on hybrid turbos to be honest.
    Apr 07 2011
    Home of the mighty beaver
    Not even on stage3.
