Results 1 to 16 of 16
    Junior Member One Ring
    Sep 03 2019
    Baltimore
    Oil Change Friendliness
    Just completed my 1500 mile oil change on my 2024 SQ5 Sportback and what a piece of cake. Bought the FCP Euro oil change kit for $108 then pop the hood, pull the oil access tube plug, insert oil extractor tube (borrowed a friends oil extractor), suck out the existing oil, change the oil filter, refill with fresh oil. Quick, easy, no mess and about half the price you'd pay to have a shop do it - I'm sure much more savings relative to what a dealership would charge.
    Veteran Member Three Rings jcoleman_11's Avatar
    Apr 21 2016
    Toronto, ON
    Yup, oil extractors are a game changer.
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    call me crazy but I still jack the car up and drain from the bottom.
    Less than $100 out the door at the local dealership for 8 quarts, an oem filter, drain plug, and crush washer.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jul 13 2018
    Winnipeg, MB, Canada
    Did you examine the filter for glitter?
    2018 Audi RS3 - Ara Blue, Black Optics
    2019 Audi SQ5 - Manhattan Grey, Black Optics
    Jan 30 2024
    Tampa, FL
    Quote Originally Posted by DudewithSQ5 View Post
    To clarify, you changed the oil after the first 1500 of use of the car? I plan on doing that too after the first 1500-2000 miles when mine arrives in July.
    Mar 25 2024
    Central NY, US
    I tried an extractor last time and I couldn't get all the oil out. Ended up doing it the old fashioned way. Maybe it was a bad extractor so I exchanged for a new one. Will try again next time to see if any better luck.
    Sep 03 2019
    Baltimore
    Quote Originally Posted by SQ5-4RiNGS View Post
    Yes - first 1500 miles on the engine.
    Sep 03 2019
    Baltimore
    Quote Originally Posted by TheContrarian View Post
    Just a cursory look. I'll change the oil again at 5000 miles then every 5000 afterwards. If contaminents were/are present, hopefully they'll be gone by 5000 miles.
    Junior Member Two Rings DazzA4's Avatar
    Dec 06 2018
    A4 B8, Honda CR-V, & multiple BMW motorbikes
    Lakewood, WA, Pacific Northwet
    I fully get why folks would go the easy way for quickie oil changes, a huge time saving for one. But, if you're dropping the engine panel beneath, whilst slowly draining the oil into a tank, having a good squiz (look around) with a torch (flashlight) in your hand, you'll likely catch things you might not if you're only doing what's always been a bottom job from the top.
    OK for newer cars, maybe not so for anything with a coupla miles on its odometre.
    2012 A4 B8 2.0L Quattro 8-speed ZF, S-Line Sedan in white - H&R blue -30mm springs, Bilstein shockies, S4 F & R brake discs & S4 rear callipers, Akebono pads, UK-made Wezmoto steel braided brake hoses, 034 trans mount, ECS 17.5mm wheel spacer set.
    Motos: 1977 BMW R75/7, '93 K1100RS, '93 K11 w/K12 engine, '95 R100 Mystic, '96 K1100RS, '98 K1200RS, '06 K1200R, & 2009 K1300GT.
    Established Member Two Rings unluky's Avatar
    Apr 29 2023
    2015 BMW X5 35i / 2004 BMW Z4 3.0 Sport
    Sedalia, MO
    Quote Originally Posted by DazzA4 View Post
    Agreed - I always take the time to have a look around while I am under there. Gravity tends to hide things from you sometimes. LOL. But I have a nice ship with a sloped pull up, so ramps and air suspension to high and I can easily get to all of it. The extractors are great for a quicky before a trip or people with limited space tools for sure though. Pick your poison. Either way is pretty easy.
    Mar 25 2015
    Placer County
    something always made me nervous about the extractor method, considering the heavier metal bits and stuff are usually settled at the bottom of the pan, and you don?t really have gravity to pull them out and you?re also not at the lowest point of the pan. idk.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Senior Member Two Rings jester7677's Avatar
    Mar 24 2007
    NH
    Put the car in its highest setting, drive up ramps, park, put the car in tire changing mode. Remove the underbody protector and drain. Peek around for leaks, debris or fraying.
    The underbody covering couldn’t be easier on this car.
    2018 Audi SQ5
    2017 Audi TTS (gone)
    2004 Audi S4 (gone)
    2000 Audi S4 (gone)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    It's very easy to do the same inspection while the oil is extracting.. and with all the time saved you have MORE of an opportunity to inspect more thoroughly.
    2019 SQ5 Prestige
    Apr 01 2007
    houston texas
    Quote Originally Posted by Gunnarrrrr View Post
    With FCP euro you send back your old oil, filter, washer for a full refund.. try that at your local dealership.
    2019 SQ5 Prestige
    Established Member Two Rings kennysexypants's Avatar
    Mar 30 2018
    Quote Originally Posted by texasboy21 View Post
    Enjoy this while it lasts :) I am certain this won't go on forever. They keep making more and more rules around it for returns. It's only a matter of time before they get rid of returning used oil.
    Managing Director - ROWE Motor Oil USA - Factory Approved, Made In Germany Lubricants.
    Previous: 2016 A6 FSM Premium Plus S-Line 3.0T - Roc-Euro Intake - APR Stage 2 Dual Pulley - APR Ultracharger - Svarog Performance Ported Blower - CAP Test Pipes - Cende Valvetronic Exhaust with Resonated Downpipes - H&R Springs - 20x9 +35 Verde Axis V99 Wheels - Firehawk Indy 500 Tires 255/35/20 - RS6 Grill - Carbon Goodies - Audi Virgin
    Mar 25 2015
    Placer County
    one way to make sure they stop doing this even sooner is to keep taking advantage of what was supposed to be a joke that you do once
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
