Results 1 to 4 of 4
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Cost to replace 2017 Q7 Engine Mounts
    Hey guys,
    Our 2017 Q7 3.0 is in the shop for a new starter (big bummer from a cost perspective) and, the dealer suggested we get new engine mounts for about $2,400 due to signs of leaking hydraulic fluid. No rough idle, etc.. Sounds expensive, and not currently necessary.
    At 95K miles, not sure how many more years we'd have the car.
    Any sense of:
    (1) how many miles we can get out of allegeldy leaking mounts?
    (1) how much a leg indy would charge for the job?
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    It was noted that our mounts were leaking at 86k but no harsh NVH or other indications of "bad" mounts. Audi wanted $2500, the euro indy did it for $1500 using OEM mounts. The mounts are what's pricey at $4xx per side. Labor was around 5 hours.
    If you're not planning on keeping her much longer, I would say leave it as is. These mounts supposedly can leak for a long time before the mount itself goes bad (collapses, NVH, etc.) but YMMV depending on how long it's been leaking already and condition of the rubber.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Jun 19 2020
    Summerfield, FL
    Check ECS tuning or 034 motorsports ...
    2015 Audi S4 (totaled )
    2017 Audi S6 Wickedly quick | Prestige w/ Black Optic | H&R sway Bars |Eurocode Alu Kreuz Drivetrain Stabilizer | 034 transmission and differential inserts | SRM driveshaft carrier bearing | SRM shorty intakes w/ RS7 airbox | APR ECU stage 1 and TCU | APR (non-res) catback | Giro Disc Front rotors w/ EBC Yellow pads │ 034 2 piece rear rotors w/ Hawk HPS 5.0
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Thank you both. Even at $200 per hour (including shop supplies, taxes, etc....) it seems the job should be well under $2K. I called an indy who had done tuning for me in the past. They suggested it's likely the car won't really need mounts or anything suspension related for a while. Suggested next oil change they'd check everything and give me best guess and estimate on a per job/total basis. But, costs would be substantially lower than dealer. Oil change less than dealer - so, I'm saving money right there.
    Meanwhile, the Q drives like a tall luxury car even with "high miles." Don't want to spend money where unnecessary and don't want to replace it.
