Results 1 to 9 of 9
    Junior Member Two Rings
    Jan 21 2023
    Dodge Demon
    Michigan
    Stock 2024 RS7 Draggy 0-60 runs
    I was able to do a few 0-60 runs with the draggy today. Have the 2024 performance, bone stock (for now). Temps are still in the low 40's so the tires have a hard time getting traction. I did 2 runs using the launch control and 2 just mashing the gas. There's a big difference in times. The quickest run was 3.38 or 3.15 (1ft. rollout) using launch control in RS2. Quickest time just mashing the gas in RS2 was 3.82 or 3.53 (1ft. rollout). I'm getting quite the bog right out of the gates with either method then it pulls hard around the 15-20 mph mark. I assume that's the traction control trying not to spin. Even though it's "off" I'm pretty sure it's still trying to work a little bit.. So there you have it.
    I'm going to try again when it warms up a little to see if there's any improvement with traction or that bogging effect. Since I don't have any tuning options yet, do I get a Eventuri intake? They claim significant gains on stage 1 cars and with the bigger turbos in this would I see similar results?
    May 08 2023
    1963 Jeep J300 1983 Z28
    Kansas City, MO
    Thumbs up
    Thanks for the info. I am also wondering what can be achieved with simple bolt-ons like intake, inlets, res delete ... is there anything else? How about some underdrive pulleys
    I am not too keen on a 10k exhaust. My car recently hit a coyote so I am putting in CFE intercoolers since one needed to be replaced anyway. I figure it is 1200 off the CFE since that is what one replacement intercooler cost and it will be ready for a tune if I keep after warranty expires.
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    APR boasts an intake that will allow turbos to spool quicker and add power/torque and make the cars quicker. I have a hard time buying that. But, a simple stage 1 tune - from most tuners - will add boost and immediately available torque. That alone should drop 0-60 times, if that's what you're after. I've read exhaust doesn't do anything but sound "more cool."
    Seriously, though, with 6300ish HP and 600TQ moves a 5,000lb car pretty well. Also, when you hit a private road check your 1/4 mile and 60-130. You'll be hauling ass in comfort!!
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Quote Originally Posted by JWebb_C7_Comp View Post
    What kit is delivering 6300hp and where do I sign up? Haha
    Veteran Member Three Rings Time4Audi's Avatar
    Jan 15 2007
    Massachusetts
    Thanks for this, curious what your G-meter maxed out shows with these results
    Jan 21 2023
    Dodge Demon
    Michigan
    G meter in the car registered 1.14 for this run.
    Jul 11 2022
    UT
    I noticed an improvement on throttle response/turbo spool-up time when I installed my IE intake.
    2023 RS6 - Daytona Grey, Blk/Red Interior, Blk Optics, XPEL Stealth, XPEL gloss interior, Full Res Delete (all 3), Lowered w/ Factory Scan Tool, 10m/12.5m spacers, IE Intake
    Jan 22 2021
    South Africa
    Is there any Ecu and Tcu software available for the new Rs7 C8 Performance. What other mods are available
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by FBAnder View Post
    My bad… 630 hp. Not 6300.
