Basically the TL;DR is this - I replaced my passenger headlight as the bottom DRL LEDs had stopped working. I know, seems heavy-handed but replacing that LED module requires disassembling the headlight. No thanks! Either way - replaced it and everything works great... I even might have to replace my driver headlight since the DRLs are now mismatched in their color. But the aiming is off and I need to adjust the passenger headlight up. I tried fiddling with the adjusters on the headlight but got nowhere that I could tell.
Is there a trick to this I'm not thinking of? Do I need a VCDS cable or a OBD11 dongle to put the headlights into some kind of "adjusting" mode? Any help here is appreciated!
