Results 1 to 2 of 2
    Mar 05 2024
    allenton pa NA
    clutch adaptation help
    Hey need some help doing some clutch adaptations. Had flashed Kyle's tune, went on to follow his next instructions for the adaptations on VCDS.
    ATF temp 42C
    no fault codes
    step 1 is "IDE02294 - Main pressure valve calibration"... this finished correctly.
    step 2 is IDE02295 - Calibration of clutch valves"... this failed. Response was "aborted-safety reasons"
    Then I receive a transmission malfunction: no reverse gear message.
    Step 3 would be "IDE02298 - Adaptation of clutch kiss points".
    I've followed Kyle's instructions before and it worked fine. However this time I cannot get it to pass calibration of clutch valves. Any guidance would be much appreciated.
    Veteran Member Three Rings IllusionalTA's Avatar
    Aug 16 2009
    06 A4 2.0T Sline M6
    Long island ny
    the safety reasons is likely cause the e brake wasn't applied..
    Quote Originally Posted by dja03 View Post
    ATF temp 42C
    no fault codes
    Steve
    17 S6
    10.3@137
    95 Firebird
    408ci Turbo LSx, 1100whp
