Results 1 to 17 of 17
    Dec 15 2020
    Romania
    New RS5 Engine Revision? 2.9L DECC Engine Code 470 WHP
    Hello all,
    I've stumbled upon this information while browsing partslink.com and could not find any other info about this engine code.
    Based on this info they start mounting this engine in cars from March 2024.
    There is also a new revision of the 0D5 Gearbox.
    Any ideas of what they are launching?
    2018 S5 Sportback - Mythos Black
    APR Stage 1 > 034 Stage 2 > EPL Stage 2 FBO & Stage 3 Hybrid TTE710 > 034 Stage 3 TTE810
    Wagner FMIC; Wagner HF DP; MTS Intake; Pre-Muffler Delete; 034 Inserts; Michelin P4S
    2019 RS5 Sportback - Daytona Gray
    APR Stage 1
    Nov 24 2007
    RS
    EU
    Same info in ETKA and RS4 B9.5 get the same engine...
    Jul 16 2018
    Atlanta
    The fourth letter denotes the tune level. So it's still a DEC engine, but with a new output definition, given letter C. The fourth letter is random by engine, A doesn't mean the same thing from engine to engine, etc.
    DECC 346 kW = 464 bhp, vs. DECA 331 kW = 444 bhp. So similar to the CAEB > CAED and CPMA > CPMB bump for MY14 on the B8 2.0T. Just some ECM tweaking for some more numbers. I wonder if the redline was raised. That the programming of the 0D5 is updated is probably not surprising, thus new trans code.
    Will this be tied to the comp pack, or just provided across the board? Who knows.
    May 03 2021
    Twin cities, MN
    Interesting stuff. Not sure why Audi is making changes this late in the game for the RS4/5.
    + To add to this, I recently bought a 2023 RS5 Competition and got it dynoed at 440whp = ~520+ Crank HP. I've done some dragy testing and It's Noticeably faster than my non-comp RS5 I had previously.
    1/4mile: 11.5 @118.43MPH (I actually know someone who managed to trap 119.83 stock). 0 to 60 in 3.3seconds (3.15 with roll out). and 100 to 200 in 9.15 seconds. That 100 to 200 time was quite surprising because it puts it in the same territory as a BMW M3 touring based on reviews I've watched from the AutoTopNL Youtube channel.
    Not sure what to make of what OP Posted but I think I can confidently say that 2.9TT is getting faster the older it gets.
    Apr 05 2012
    Earth
    Quote Originally Posted by ragy17001 View Post
    Brand new or used? Various tuners and other people have said they've dynoed the Competition model and the HP is the same as the non-Competition model. Plus, the Competition uses the same engine code as the regular RS5 meaning it has the same tune from the factory.
    Apr 19 2019
    Toronto, Canada
    Most M3/M4 Comps are doing high 7's to low 8's 100-200. AutoTopNL did a low 7 in the M3 CS (same as the M4 CSL). The touring might be a bit slower but I can't imagine it's over a second slower.
    Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
    Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
    May 03 2021
    Twin cities, MN
    Quote Originally Posted by JohnEnglish View Post
    Bought it used with 5k Miles but I've done my due diligence and checked in with Audi of St. Paul to make sure it wasn't tuned.
    What tuners have come out and said there isn't any differences between the comp and non comp? Couldn't have been 034 right? because "a4 4snow" on this forum has spoken with 034 and they told him Audi shifted the power band around on for better performance. Another thing to mention is his comp also made ~20+ more horsepower than any other RS5 they've ever tested. Similar to my dyno results. You can find all this info on the RS5 Competition Owners corner Thread.
    May 03 2021
    Twin cities, MN
    Quote Originally Posted by Burrcold View Post
    Surprisingly the M3 Touring is noticeably slower than the Sedan and Coupe.
    Here's the AutoTopNL video I was referencing for my 100 to 200: https://www.youtube.com/watch?v=-AGj...nnel=AutoTopNL
    Another thing to note is that the another channel (Automann-tv) managed to pull off a 8.9 with the RS5 Competition Coupe. Which makes sense, since its ~100lbs lighter than my RS5 Comp Sportback.
    Here is that video if you want to check it out: https://www.youtube.com/watch?v=kJEQ...RpdGlvbg%3D%3D
    Veteran Member Three Rings ywang98's Avatar
    Nov 02 2018
    Orange County, California
    This may explain why I am feeling more power in my 2024 RS5 Comp. It is definitely different than my old 2021 RS5. The torque seems to be higher as I was surprised today going up a hill that I traveled with my 2021 RS5 as well. In the old car, I had to push down the pedal to maintain speed, but it would downshift in the middle of the climb. The new car today, I did the same thing, and it never downshifted and kept pulling a little more (all in 8th gear).
    Apr 05 2012
    Earth
    Quote Originally Posted by ywang98 View Post
    What engine code is in your car? The new DECC engine is schedule to be installed in cars starting this month.
    Apr 19 2019
    Toronto, Canada
    I guess almost 200 extra lbs will do that (touring vs sedan). Yet another reason I would never buy a wagon even if it was available in North America.
    Jul 25 2023
    Chile
    I have RS5 2022 coupe stage 2 custom 91 RON + E10 100-200 7.3s and I still feel it slow =/
    That's why I want to update the turbos for 5.xS 100-200.
    Apr 19 2019
    Toronto, Canada
    Quote Originally Posted by Enzoba View Post
    If you think low 7's is slow, you should probably get another car. 992 911 Turbo S? Low 6, low 5 with a tune.
    Jul 25 2023
    Chile
    It is cheaper for me to modify my current car. exploring a platform is much more entertaining but at the same time risky. With methanol injection you can get a good improvement. The problem is the intake manifold is asymmetrical.
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    With an engine upgrade, does that mean there will be a 2025 RS5? How long will they keep building the current platform?
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Nov 03 2016
    CA
    Quote Originally Posted by VVG View Post
    If the 2025 is still on the B9 chassis then that’s just sad.
    I have loved Audi since I was a kid, but their extremely slow release of new models and stagnation in performance have really caused me to become jaded.
    To put it into perspective, the G82 M4 LCI refresh will start landing soon…and we are barely getting spy shots of the B10.
    To add insult to injury, all rumors are pointing to Avant and sportback only. No coupe :(
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
    Apr 05 2012
    Earth
    Quote Originally Posted by brilliant_black View Post
    The B10 RS5 will be Avant only.
