Results 1 to 23 of 23
    Dec 24 2022
    2023 RS 3 in Tango Red
    MA USA
    TPMS Activation and Wheel / Tire Set Swapping
    Hi All,
    Last season I tracked a few times with the stock wheels and loved the fact I could monitor pressures and air temperatures (not tread temps obviously) using the Sport display. For this season, I was hoping I could drive to my track events on my OEM wheel / tire setup setup and swap to my new track wheel/tire setup when I get there and still have direct TPMS data on the MMI. I just got a new track wheel setup with direct TPMS sensors from Neuspeed RS Wheels but I haven't ben able to get the car to recognize the new TPMS sensors yet. Going back to the shop that mounted the TPMS sensors and tires on the new wheels to troubleshoot this week.
    In the meantime, I'd like to hear form others who are successfully swapping out track / street or summer / winter wheels sets and what you need to do to get the TPMS sensors working each time you swap.
    Thanks.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by stummiller View Post
    Hi All,
    Thanks.
    I’ve probably swapped 20 sets of wheels since 2019, always used OE sensor never once had to do anything more then go into the mmi and select “store pressures now” , pressures and temps always should up after that and once you drove over 15mph for the first time after reset.
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    swapped wheels mee to, using Audi genuine sensors and they started working after a while (maybe 5/7 miles or so).
    @o1turbo30v: are you sure you can store the pressure even when the display shows the -- ?
    2020 TT- RS
    ex 2018 TTS
    Jul 21 2014
    United States
    OEM sensors?? I think the dealer quoted me $1300 just for the parts, no labor.
    I got a set on eBay for like $150 for my winter wheels/tire setup. They have worked for a couple seasons without issue. Part number and seller: https://www.ebay.com/itm/38380840172...mis&media=COPY
    Veteran Member Three Rings 993140's Avatar
    Oct 14 2012
    GT3 Touring
    Way Out West
    Viken
    2024 RS3
    2023 S3 Premium Plus
    Senior Member Three Rings sleepy_rs3's Avatar
    Mar 29 2021
    New York, NY
    +1 on these - i have multiple sets from them which come pre-programmed and have worked without issue. at their price i never swap, just have sensors in my winter wheels/tires, and anoter set in my summers.
    2019 Glacier White RS3 | Unitronic Stage 2 ECU & TCU | Unitronic Downpipe, Intercooler, & 4" Turbo Inlet | CTS 4" pipe to stock airbox | 034 intake heat shield | DSC Sport Controller | Tyrolsport Deadset Subframe Kit | 034 Street Density dogbone kit | Valentine 1 Gen 2 Radar Detector with JBV1 app
    Aug 11 2019
    Rome, Italy
    Quote Originally Posted by GTItoS4 View Post
    1300$ is crazy, I spent 125$ for a set of 4 on ebay...
    https://www.ebay.it/itm/185618808849
    2020 TT- RS
    ex 2018 TTS
    Dec 24 2022
    MA USA
    Quote Originally Posted by sleepy_rs3 View Post
    Are you 8V or 8Y?
    Mar 29 2021
    New York, NY
    Are you 8V or 8Y?
    8V but they have them for 8y as well https://www.tpms.com/2023-Audi-RS3-TPMS-s/10645.htm
    Dec 24 2022
    MA USA
    Ok. For what it’s worth, I am seeing several 8Y owners having the issues. 8V seems to be fine.
    Mar 29 2021
    New York, NY
    Bummer! They came pre-programmed and worked seamlessley on the 8V. Perhaps people didnt get the pre-programmed ones? Also it may be worth calling TPMS.COM and discussing their return policy or guarantee of compatibilty.
    May 09 2023
    2012 Shadow Blue VW GTI
    Sacramento, CA
    Order from neuspeed rs pre coded to car. Works fine on my wheels.
    Junior Member Two Rings
    Dec 23 2023
    California
    that's really cool. When they arrived coded, did you have to do anything special to pair them with your vehicle? When you swap them each season, does it remember both sets, and do you have to do anything when you switch to get it to read one over the other?
    Jul 21 2014
    United States
    I'm an 8Y and using the eBay ones I linked without issue.
    Mar 29 2021
    New York, NY
    Quote Originally Posted by RS3sistable View Post
    Nothing special to be done…if you get impatient I think re-storing tire pressures helps speed things up. I usually do that because I am a bit impatient. Your car reads them off of a local antenna so after swap it will pick up whichever are mounted on the car. I’ve had two sets of wheels with sensors for 4 years now both sets with sensors from TPMs.com. My original OEM wheels/tires still have the OEM sensors in them. Haven’t used those wheels/tires for 3+ years.
    Dec 24 2022
    MA USA
    Are you 8Y (2022+) or 8V?
    Mar 29 2021
    New York, NY
    8V
    May 05 2022
    TX
    I have my OEM sensors on my track set of wheels. I have a warning whenever I have my daily wheels on, which is annoying, but I care more about my pressures on the track than street. I'm going to buy sensors the next time I change my street wheels. Not sure when that will be though cause they see much less wear. Hopefully there's a good solution for the 8Y.
    Established Member Two Rings DAP's Avatar
    Mar 16 2004
    8Y here. I used the sensors from tpms.com without any issues.
    When I swap on the winter wheels and started to drive, the MMI recognized the new sensors and prompted to store the tire pressures.
    Pretty seamless.
    Dec 24 2022
    MA USA
    Quote Originally Posted by DAP View Post
    Pretty seamless.
    Problem solved. Went to local VAG performance shop for alignment and they were able to reset the TPMS warning with ODIS, filled the tires up to 45 psi, and on the way home the sensors kicked in. So maybe just had to wake them up with a bump in pressure? Regardless, now back in business.
    Jan 02 2019
    Looking at tpms.com, I see there are 2 brands: Upro vs. Huf. Any difference between the 2?
    I see Huf is pricier (Front: $69.98/pcs & Back: $34.98/pcs) and Upro is a set for $109.96.. Not sure which one to get
    Aug 05 2022
    MI
    I got OEM ones from eBay for $120 a set. No issues with my 8Y seeing them once installed.
    2022 Audi RS3, Glacier White, Tech Pack, Black Optic, Eventuri Intake, Unitronic Mid-pipes, APR Exhaust
    Jan 02 2019
    Quote Originally Posted by SVTunit View Post
    Do you have the link handy? Much thanks!
