Results 1 to 31 of 31
    Veteran Member Three Rings jpenneck's Avatar
    Dec 14 2006
    Denver, CO. USA
    2019 RS5 Sportback suspension(?) issue
    I have been experiencing an issue recently where I hear a clonking noise from the rear of my car when I drive over uneven surfaces at slow speeds e.g. parking lot cracks etc. My son reckons the shocks are likely leaking and/or there is an issue with the suspension accumulator. Neither of us have had a chance to look under the car yet so figured I would ask here to see if anyone else has had a similar issue...
    My car is going into the dealer this Friday and I will report back on what I find out.
    2019 RS5 SB - Navarra Blue, Alu Optic Carbon, Dynamic package, Driver assistance, B&O, 5-arm-peak wheels.
    2019 Q5 - Florett Silver, Prestige
    2013 RS5 - Sepang Blue, Alu-Optic, Black Alcantara, Nav, Sports Exhaust
    2012 S4 - Monsoon Gray, Prestige package, S-Tronic, Sports Diff
    2007 RS4 - Mugello Blue
    2000 S4 - Santorin Blue
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    Potentially a DRC failure. DRC failures are very common on other platforms, like the B7 RS4. They haven't been as common on the B9, but we're starting to see more of them unfortunately.
    That said, it could be some other suspension component, like a sway bar end link. An easy way to tell is to change suspension modes. If the noise goes away or changes (e.g., it's less frequent), then it's likely the DRC. If the noise is the same regardless of suspension mode then it may be another component.
    Usually the DRC fails as a result of a leak. But the leak isn't always visible or obvious and some folks have reported DRC accumulator failures (which causes clunking as well) without any visible leaks. So good call on taking it to the dealer to pinpoint the issue.
    Please keep us updated. I also have clunking under similar condition and I'm pretty confident it's the DRC. Once I confirm it's the DRC, I'm probably just going to swap it for a KW V3, Abt coilover, or KW V4.
    2019 RS5 Sportback - Nardo, Black Optic Carbon Package, 034 Stage 3, TTE720s, AWE downpipes, APR intake, Wagner IC/HX, 034 HPFP, ABT H.A.S., BBS CI-R, E-Codes, Bull-X res delete, 034 rear sway, 034 trans/subframe mounts
    2025 Audi SQ7 - Wife's daily
    2015 Audi S3 - Unitronic Stage 2
    2002 Porsche 911 Turbo - AMS billet K16's / EPL tuned
    2006 Trailblazer SS - bolt-ons
    2001 Audi S4 - EPL stage 3+
    Jun 12 2019
    Newton/MA/USA
    I have an occasional passenger who is an ex-mechanic, and when sitting in the RR passenger seat, says that he can hear "noisy" RR strut or "strut-top" when traveling over bumps at low speed. I can't hear it from the driver's seat. At the last service interval just a few weeks ago, I asked the service department to inspect my struts and strut tops. They did (and sent me a video of them inspecting it), and said everything looks fine. Who knows, ...
    2019 RS-5 Sportback | Nardo Gray | Dynamic Plus | Dynamic Steering | Dynamic Ride Control | Driver Assistance | Black Optics | Napa leather | B&O | 275/30 R20 Continental DWS06+(f)/DWS06(r) | Bosch Passenger Sport Gauges
    Senior Member Three Rings zac3707's Avatar
    Nov 10 2020
    US
    willing to bet its the DRC failing, keep us updated
    Apr 06 2021
    New York
    Sounds like DRC failure, I had the same noise and that was the cause.
    May 18 2018
    Illinois
    I got my 2019 back from the shop yesterday. Same sound. Thankfully still under warranty. Had leaky DRC valves replaced ($4,000!) and new mufflers (due to the noisy exhaust flap).
    Dec 14 2006
    Denver, CO. USA
    As suspected, it was a DRC failure and both rear shocks need replacement. Unfortunately the car is out of warranty but it's less than 5 years old with only 16k miles as it was driven very little during the pandemic. The price quoted was an eye watering $5300 which obviously promoted some complaints about this excessive repair bill to the service advisor. At my request he is going to see if the dealer or Audi can do anything but I'm not going to hold my breath.
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    Quote Originally Posted by jpenneck View Post
    You can get the equivalent of the RS5 Competition suspension for that amount of money (KW4 version):
    https://www.kwsuspensions.net/shop?c...135352&pgs=160
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, PB Pedal Tuner; AskCarbon Steering Wheel
    2021 SQ5 S/B Prestige - Daytona Gray/Black
    Mar 21 2005
    RI
    Sorry to hear! That price is unfortunately consistent with what I've seen for DRC repairs. Not to mention, I've read about people replacing the dealer-recommended parts only to have the noise remain. So they end up having to blindly replace parts until the noise is gone. It's one thing if you under warranty with the dealer eating the costs. But if you're not under warranty, throwing $5300 at the suspension with no guarantee the noise will be fixed doesn't seem like a great idea. I'm with B6_Dolphin, might as well just swap in the KW V4 setup (i.e., the RS5 Comp suspension). By all accounts it's far superior to DRC, it has a lifetime warranty, and it'll 100% resolve the knocking.
    Established Member Two Rings vexige's Avatar
    Sep 26 2015
    2019 RS5 SB, 2023 Genesis GV60, 2023 MB EQE500
    Watchung, NJ
    Exact same story... The only difference, the price quoted was $6k+
    No point of replacing with factory suspension, in my view. After much research I went with ABT HAS, (sourced by nemesis, who is amazing to work with, btw), which saved me a bundle and was installed couple of days ago. Clearly not enough time/miles yet, but my first impressions are the most positive- knocking and harshness are gone, the car feels better controlled.
    Mar 26 2010
    US
    Quote Originally Posted by vexige View Post
    So you are still using the DRC dampers, but changed the springs and noise/harshness went away?
    BMW M3 Competition X-drive
    Mar 26 2010
    US
    Quote Originally Posted by B6_Dolphin View Post
    But the KW V4 uses a stiffer than OEM spring and lowers the car a minimum of 0.4 inches?
    Sep 26 2015
    Watchung, NJ
    Quote Originally Posted by wwhan View Post
    I replaced everything and used included DRC cancel kit to avoid CEL
    Mar 26 2010
    US
    The ABT HAS does not include dampers.
    https://www.nemesisautosport.com/pro...ion-b9-chassis
    This might be a good alternative: ABT Coilover Suspension System Audi RS 5 Coupe and Sportback (B9/B9.5 MY 2018-2023)
    But it has a minimum lowering of 0.4"
    Sep 22 2021
    Hartford CT
    Same issue on my 19' SB. 40k miles. Going to my indy in a couple weeks for oil change will see whats up with it. I have also read threads about common problems with the bump stops. Keep us updated. I will report back as well.
    Dec 14 2006
    Denver, CO. USA
    I will have to wait until Monday to see what the dealer comes up with, if anything. I am not interested in lowering the car even half an inch as the sidewalk/curb in my neighborhood are not sloped at all for your driveway and you basically have to drive up a rounded curb to get on your drive which is idiotic. It is already entirely too easy to scrape the front end of the car and I always have to go on or off the drive at an angle.
    Sep 26 2015
    Watchung, NJ
    That's what I have
    Apr 10 2005
    PNW
    With either the KW 3's or the KW 4's, since they are coil-overs on the front, and adjustable spring perches on the rear, you can adjust the ride height to your liking.
    Mar 26 2010
    US
    Except, both the KW & ABT coilovers specifications indicate they provide a minimum of 0.4 inch lowering. Many people might prefer to have stock height, with NO lowering.
    https://www.kwsuspensions.com/produc...-352100cj.html
    https://www.kwsuspensions.com/produc...-3a7100cj.html
    Front Lowering: 0.4" to 1.2"
    Rear Lowering: 0.4" to 1.2"
    https://www.nemesisautosport.com/pro...=59e9c482a&pr_
    Lowering FA: 0.4 in-1.3 in
    RA: 0.4 in-1.3 in
    Mar 26 2010
    US
    One might be able to use the 15mm KW spacers, so the ride height could be at the OEM ride height, if the dampers can handle the additional extension?
    SPRING SPACER, 15MM: https://www.kwsuspensions.com/produc...-65030045.html
    Dec 14 2006
    Denver, CO. USA
    Well, I heard back from the dealer this morning and I guess it's my lucky day - Audi is going to cover 100% of the repair! It probably helped that I have purchased 7 Audis in the last 20+ years (including 3 RS models) and have had them all serviced at the same dealer. As you can imagine, I am much happier today than I was last Friday!
    Sep 22 2021
    Hartford CT
    So.......what was it!?
    Dec 14 2006
    Denver, CO. USA
    Quote Originally Posted by ZacCT View Post
    As I mentioned above:
    Sep 22 2021
    Hartford CT
    Gotcha, sorry!
    Mar 21 2005
    RI
    That's awesome news! Congrats!
    I doubt I'll be that lucky... I've been TD1 on my suspension (Abt HAS) since 2019. Even if I was under warranty, it would probably be a fight to get a DRC failure covered.
    Dec 14 2006
    Denver, CO. USA
    Minor update - I still don't have my car back. The dealer has had the car since March 1st and still doesn't have some of the parts. I do not know if this was due to failure to order the correct set of parts or if some are out of stock/delayed. Sigh......
    Veteran Member Four Rings antoff83's Avatar
    Jan 30 2009
    2019 Audi RS5 Sportback
    DEN USA
    Hi James! Hope all good with you as you cant said so about the car. Sorry to hear/read about that. Is your car at Audi Denver or you were Prestige customer?
    Tony
    19' AUDI RS5 SB | Riviera Blue | Black/Rock grey
    18' BMW X5M | Long Beach Blue | Silverstone full Merino
    17' AUDI S7 | Sepang blue | Arras red,gone
    16' MB GLE450 coupe | Diamond white | gone
    14' AUDI RS5 Coupe| Sepang blue gone but not forgotten
    04' BMW M3 Convert | Carbon black gone
    Dec 14 2006
    Denver, CO. USA
    Quote Originally Posted by antoff83 View Post
    Hi Tony,
    My car was at Audi Denver and I finally got it back today. After a quick drive home it seems to be driving great again which is a big relief as I didn't have to pay for the repairs! Both rear struts were replaced along with both central drc valves.
    Jan 23 2020
    Cali
    Do you have a video of the sound? curious if i have the same thing.
    Dec 14 2006
    Denver, CO. USA
    Quote Originally Posted by Pandemic View Post
    No, unfortunately not. It was a pretty noticeable clonking sound coming from the rear of the car when driving at slow speeds, especially over parking lot cracks or concrete expansion joints. The noise went away (as far as I could tell) when driving at faster speeds but it's possible it was just masked by road noise. Trying switching drive modes between comfort & dynamic at slow speeds on uneven road surfaces and see if your noise changes.
    Jan 30 2009
    DEN USA
    Hi Tony,
    Thats great to hear! They are awesome to work with, I work with Jared and Keith there and if you ever have any issues talk to Keith ,he is great !
    Mine is currently at 37,000 mi and I haven’t noticed anything like that. And I run ABT adjusting springs.
    Tony
