A few months ago my battery literally exploded in the car. Never seen anything like this, the battery plastic was torn open and I had acid all over the battery compartment and windshield. Almost needed a change of underwear after that experience.
This could have been caused by a wire which got loose at the light switch. Probably my fault and my janky boost gauge wiring but oh well live and learn.
I have been procrastinating on getting the car working, but tired of looking at an expensive yard ornament...lol
The car still starts but acts really weird. When started from cold it will idle at like 900rpm which is really low for cold start, the a/c controls and radio keep turning on and off and the battery light, brake light are on.
Where do I even start diagnosing this? Should I get the VCDS software? https://www.ross-tech.com/vag-com/VCDS.php to start with? How do I find out what is fried and what needs to be replaced? Should I go ahead and replace the voltage regulator anyways since its fairly cheap part?
Please help!
