Results 1 to 15 of 15
    Junior Member Two Rings
    Jan 29 2024
    2019 Audi A7 Prestige S-Line, 2017 Mazda MX-5
    NE Ohio
    Question Caliper Color: Covers vs Painting?
    Hey all, I have a 2019 A7 Prestige w/ S-Line package and I'd like to add some color to the stock gray/metal brakes. The front brakes look pretty nice and beefy other than the gray color, but the backs are just plain metal.
    What have others done for these cars? Are there good quality replacements or covers available that look nice? Or is removing the existing calipers and painting them and adding some Audi logos the best bet? Any idea how much that might cost?
    I'd love to see pictures of what you guys have done with your cars and some info on why/how you went that direction.
    Oct 02 2023
    Charlotte, NC
    IMO caliper covers look cheap, especially for 6 piston calipers. I used G2 Caliper paint. One can, 2 coats on the rears, carefully put the wheels back on, then 3 coats on the front and let it sit overnight . Added Audi Sport high temp decals from eBay.
    Jan 29 2024
    NE Ohio
    So you didn't have to remove the calipers to paint them? Did you do the rears as well? Was it hard to get the decals to stick on the rears? Good job, they look great.
    Oct 02 2023
    Charlotte, NC
    No, I didn't remove the calipers. In all honesty, you can get really good coverage on the car. Removing the calipers will let air into the system and you'll have to bleed them several times. I did the rears too, but they're just single piston sliders, so I didn't do stickers.
    G2 paint is a pretty solid product, although picking up some nicer brushes is definitely worth it. I used it when I swapped Macan calipers onto my MK7 R too.
    Oct 29 2021
    Fuquay-Varina, NC
    I had mine painted at the same time I was getting my wheels powder coatedScreenshot_20240222_210605_Gallery.jpgScreenshot_20240222_210510_Gallery.jpg
    '19 A6 Prestige 3.0
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by LegoManiac View Post
    Wow, that looks fantastic. My solution would have been to find someone willing to do powder coating, but as you noted, that means the car is out of service, air might get into the system, etc.... Nice work~!
    Established Member Two Rings JustNick's Avatar
    Jul 07 2023
    2019 A6, 2020 Q5, 1987 Bronco II
    Baton Rouge, LA
    Quote Originally Posted by JWebb_C7_Comp View Post
    I wouldn't powdercoat calipers based on one of my racing friends experience. He found that the heat would make the coating pliable again and would let contaminants like brake dust and dirt imbed in the surface and ended up with a burnt look that he couldn't get rid of without a strip and recoat.
    But he might have also used a low quality or lower temp powder
    Oct 29 2021
    Fuquay-Varina, NC
    Quote Originally Posted by JustNick View Post
    The place that did mine also told me that they paint the calipers vs powder coating like they do for wheels because the powder coating can't stand the heat from the brakes.
    '19 A6 Prestige 3.0
    Jul 16 2023
    Columbus Ohio
    Personally any time I see some one with brake caliper covers I laugh at how terrible they look. They are not fooling anyone with those things. My calipers are out right now getting coated and should have them back soon. As far as the concerns that powder cant stand the heat from brakes, if you are doing constant track time then yes you will probably overheat the powder. for an every day driver and spirited driving you will absolutely be fine.
    21 A6 Allroad 20th Anniversary
    Stage 2 Banner Advertiser Four Rings Sean@TAG's Avatar
    Jun 27 2014
    Seafox Boat, Jetta, F150, Travel trailer
    San Diego
    We paint all of ours in house :)
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    Jul 16 2023
    Columbus Ohio
    Just picked up mine from power coating. Decided against a decal because I didnt think having a straight decal on a curved face would look right.
    Oct 02 2023
    Charlotte, NC
    Quote Originally Posted by Biggu View Post
    Agree. You can't see them in my pic, but I got curved Audi Sport decals on the 'Bay. Most are straight, but curved are available....
    Jan 29 2024
    NE Ohio
    Which curved stickers did you end up going with? Could you post a picture of them? That sounds like a great option for these weird calipers
    Oct 02 2023
    Charlotte, NC
    Quote Originally Posted by BoredOhio View Post
    The wheel spokes really hide them
    These are the ones I used. They're 100mm long (about 4 inches)
    https://www.ebay.com/itm/29443139224...Bk9SR-aA_6bDYw
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    back from the dead on this one, did you pre-sand or prep the surface in anyway prior to applying G2? my stock brakes are quite a rough surface, so was curious
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
