Yeah, that's a long run. Unfortunately, the wire does not show as passing through any connector along the way. Not the 17-pins in the ECM box, not the 17-pins at the base of the left a-pillar, not the 17-pins at the base of the right a-pillar.
We know the wiring runs through the left fender.
interior harness - engine bay:
https://www.ilcats.ru/audi/?function...81&language=en
item 7 is the H12 alarm horn plug
item 8 is the grommet at the fender
union (40) is to the interior harness left:
https://www.ilcats.ru/audi/?function...82&language=en
interior harness right:
https://www.ilcats.ru/audi/?function...83&language=en
item 54 are the 32-pin plugs into the J393
How does the wire get from interior harness left to interior harness right? Via the interior harness center tunnel:
https://www.ilcats.ru/audi/?function...84&language=en
upper (50) is the left harness connection, (51) is the right harness connection.
Unfortunately, the diagrams show the connection from the left harness to the roof harness; (91) in the left diagram = the lower (50) in the tunnel & roof diagram. But neither the left harness nor the right harness actually diagram the connection point to the center tunnel harness (the 50 and 51 on the upper harness in the tunnel & rood diagram).
Suffice to say, however it gets there, you're not finding it. Because it's also not the only violet/white wire running around in the interior harness.
I've never found a good static pic of the fender pass-through (that grommet 8 in the engine bay harness diagram), so I just reference this video from Naptown. This is of the right side, but same business on the left side.
https://youtu.be/C_-MfYokbMc?t=3
