Results 1 to 8 of 8
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    20" Alzor Wheel Clearance - Blew my Tires and Bent Wheels
    Today wasn't too great of a day as I hit debris in the road and popped and bent the tires and wheels on my passenger side. Got the car to dealership I work at and its just sitting in the lot right now, so I'm looking at getting new wheels and tires. Our parts guy said 20" tires are cheaper than 19", and I like the Alzor Style 628 RS-replica wheels and am eyeing up the 20" ones (They don't ship until March 27 on ECS but EuroSport says they have them in stock), however its noted that at least a 3mm spacer is needed to clear the caliper.
    Anyone who has run the 20" Alzor 628 wheels, can you confirm what spacer setup you had? If EuroSport doesn't have the 20" in stock then I'll just go with the 19s, but do they also require spacers?
    Thanks all.
    20 Wheels:
    https://www.ecstuning.com/b-alzor-pa...four/628-13kt/
    https://eurosporttuning.com/20-style...our-es4325181/
    19 Wheels:
    https://www.ecstuning.com/b-alzor-pa...-four/628-9kt/
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Senior Member Two Rings RedSox S315's Avatar
    Jul 09 2013
    Bay Area
    Quote Originally Posted by MyDimeIsUp View Post
    Thanks all.
    20 Wheels:
    19 Wheels:
    I do not have 20” Alzor 628 wheels but based on the link for 20” that you provided, their spec is 20x9 ET30.
    For reference, on my 2017 S6 I am running RS5 black optic wheels which are 20x9 ET29 and they fit just fine, no spacers. My tires are 275/30.
    Maybe I’m missing something here but I don’t think you need any spacers.
    2017 S6
    2014 S4 - [SOLD]
    Veteran Member Three Rings base14's Avatar
    Jun 01 2017
    OR
    I’ve always liked the rotor design. So much so that I have two variants of the 628 for my summer and winter setups. I can confirm the Alzor 628 20x9 et30 WILL absolutely need a minimum 3mm spacer to clear the front caliper cover bolt.
    For winter, I have the 19x8.5 et45. Those also would not fit without spacers but I had some on hand that I planned on using from the start to give me a flush look. The OEM sport 20” wheels were close to this being 20x8.5 et43-45(?) can’t remember which, so I wanted to keep close to those specs with the 628. I ran 12mm/20mm F/R spacers on my stock wheels, zero rubbing issues, and run the same setup on the winter Alzor 19s.
    Some considerations: 20” tires will be more expensive. But the concavity on the 20x9 is significantly more than the 19x8.5. The 20s are much more visually striking imo and closer to that aggressive rs look. If I only had one wheel setup, I’d go with the 20s. I’m guessing here but the reason Alzor has fitment issues is the thicker design on the inner portion of the rotor.
    19s with +12mm spacer
    20s without spacer, contact with bolt.
    2018 A6 3.0t P+ Competition Package| 034 Stage 1 ECU+TCU (his)
    2015 Q5 3.0t P+ S-line | EPL Stage I (hers)
    (SOLD)2013 allroad Prestige | APR Stage II | E85
    (SOLD)2010 Q5 P+ | OEM+ Build Thread
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by base14 View Post
    Thanks for the info! Unfortunately even EuroSport Tuning said the 20" 628 wheels were out of stock until, at the earliest, March 27th. I couldn't wait that long and the 19" wheels I wasn't too sure of since I've been eyeing 20" wheels for awhile now. I also really need my car since this next week and especially this month I'm going to be doing A TON of driving. I picked up some C7.5 20" wheels which I'm really happy with (both the design and the price w/ tires). They're pretty tucked in (ET 45) so some wheel spacers and especially coilovers to lower the car and she'll be set.
    Thanks for your help and info.
    2007 Toyota corolla
    Jun 01 2017
    OR
    No problem. They look good! I’d say you’d need a similar spacer setup as mine to flush the wheels. 12mm front, 20mm rear
    Dec 04 2019
    West Chester, PA
    Most def, they're so tucked in right now (ET 45). Also coilovers because the wheel gap is insane
    2007 Toyota corolla
    Junior Member Two Rings
    Nov 02 2023
    Naperville IL
    I have those same wheels and I’m also looking to get rid of them to get the alzor 628s haha
    Jun 19 2020
    Summerfield, FL
    The website states that a 3 mm spacer minimum is required ...
    2015 Audi S4 (totaled )
    2017 Audi S6 Wickedly quick | Prestige w/ Black Optic | H&R sway Bars |Eurocode Alu Kreuz Drivetrain Stabilizer | 034 transmission and differential inserts | SRM driveshaft carrier bearing | SRM shorty intakes w/ RS7 airbox | APR ECU stage 1 and TCU | APR (non-res) catback | Giro Disc Front rotors w/ EBC Yellow pads │ 034 2 piece rear rotors w/ Hawk HPS 5.0
