To put it short I’ll be doing:
Fully forged built EA113
G25-660 Reverse Rotation
Tiptronic to O1E 6MT
Current Parts List:
- AMC Assembled Head w/ Camshafts
- ARP Head Studs
- ARP Cam Tower Bolt
- IE ARP Crankshaft Damper Bolt
- Ferrea Valves, Springs & Retainers
- IE Billet Adjustable Camshaft Gear
- IE Billet Press Fit Timing Belt Drive Gear
- IE Intake Manifold
- IE Billet Valve Cover
- IE 2.0T FSI Catch Can Kit for IE Billet Valve Cover
- 06F103011J Short Block
- 06A105021BP Crankshaft
- A2B JE Piston Set
- FFE Racing X Beam Connecting Rods
- Calico Main & Rod Bearings
- Fluidampr
- 034 Engine Mounts
-034 Snub Mount
- Balance Shaft Delete
- Garrett G25-660 Reverse Rotation T51R IWG
- BarTek 2.0L TFSI & TSI Turbo Manifold
- ECS Luft-Technik Intercooler and Charge Pipe Kit with/ Power Steering Cooler
- ECS Kohlefaser Luft-Technik Intake
- IE HPFP
- A2B TTRS Fuel Pump Kit
- RS3 Injectors
- iAbed TSI Cam Follower Conversion Kit
- Torqbyte PM4
- 155 Bar PRV
- Tip to 6MT Swap Kit (O1E Transmission)
- South Bend Clutch Stage 3 Daily Clutch & SM Flywheel
- Coolerworx Carbon Short Shifter AUDI B3 B4 B5 B6 B7 C4 C5 C6 Black/Silver
- Bilstein B14
- 034 Density Line Complete Front Control Arm Kit
- H&R Front and Rear Anti-Sway Bar Kit
- B6 S4 18” Avus Wheels
- Toyo R1R 245/40/18
- JHM Cayenne 350mm Front BBK
- OE Rear Calipers w/ StopTech Street Slotted Rotors
- B7 DTM Front Bumper
- OSIR B7 A4R Carbon Fiber Grille & Surround
- OSIR Carbon Fiber Grille Rings Logo Support
- Faithful Rainbow Carbon Fiber Euro Trunk Lid w/ Integrated Lip Spoiler
- Faithful Rainbow Carbon Fiber Vented Front Fenders
There is still a ton of miscellaneous pieces I’ll need along the way, which will come as they are needed. Some parts will also be taken off the existing engine, like the oil pump, water pump, etc.
Would like to ask suggestions for a turbo kit, if there are any that can reach my 400awhp goal still on the shelf - I’ve seen ATP’s are discontinued and RAI no longer sells theirs in house or online. All I can find now is JHM’s TD05H-R but I don’t think it’s enough.
I’ll add pictures to the thread as it progresses.
Edit: State of the car at the beginning.
