Results 1 to 40 of 51
    Apr 17 2023
    Durban
    ASR valve control
    Anyone do the ASR valve control mod over a hardware change like a mid pipe and does it make a big difference?
    I have the sport exhaust
    Is the valve control just mimicking the sound you get when you in RS performance over 4K rpm but just in lower rev range or does it do something completely different ?
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    I have ASR module on my TT-RS and I think it's worth the money, but I don't think it increases the overall sound level, if you are looking for this, you have to work on the exhaust line (replacing the EOM midpipes and/or downpipe). When I replaced the OEM downpipe in favour of an hi-flow Milltek downpipe+midpipes, the sound has completely trasnformed both in terms of dB and note...
    2020 TT- RS
    ex 2018 TTS
    Apr 17 2023
    Durban
    Quote Originally Posted by kevin#34 View Post
    Thanks for the feedback.
    The issue I have it with warranty in my country. So hardware mods will be a problem.
    If I can emulate the sound when it’s in RS performance but in comfort mode then I’m happy
    Sep 12 2022
    South Jersey
    So what would you say is the advantage of the ASR module is, then?
    Jul 15 2022
    US
    Quote Originally Posted by skinnyD View Post
    It'll do that for you. It isn't emulating anything though, there's no imitating. If you're in comfort you can open the valves like it's in race mode. For at least a month now I've been driving around in comfort, but with the valves wide open.
    Aug 11 2019
    Rome, Italy
    as above.
    main advantage of the ASR module is the flaps autonomous management possibility.
    almost undetectable by Audi (can be easily reverted to std mode with a press of the S&S button)
    last but not the last, can deactivate S&S permantenly (ok, not of interest for you US model owners), that from 19 YM cannot be done on the usual way (VCDS) anymore
    2020 TT- RS
    ex 2018 TTS
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    Any of the Valve controllers do just that, control the factory exhaust valves so you can keep them open at all times instead of only in certain modes.
    2024 RS3 Kemora Gray
    Mar 24 2013
    Toronto, Canada
    I installed the Cete valve controller on my vehicle as first mod- Best money spent so far, this is how the car should sound from the factory with valves open.
    In my opinion its worth the money just for the fact that you don't have to put the car into dynamic mode every time you start it and you want the flaps open. Also i noticed previously even in the dynamic mode when the rpms would go down bellow 1500rpm the flaps would partially close, now they stay permanently open and it makes the car sound so much better in the lower rpms
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Quote Originally Posted by 4g63turbo View Post
    Exactly this. Even in Dynamic + S the flaps will still open and close at low rpm/load. I added an AWE exhaust to my RS3 and couldn't believe how terrible it was due to the OE valve logic. It was constantly getting louder or quieter depending on load.
    After installing the CETE valve controller, it was much better and a more consistent sound.
    Apr 17 2023
    Durban
    Just had this installed. Noticeable difference in all driving modes.
    I’m quite impressed
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    Technically one could unbolt the valve controllers (leave them plugged in) and force position to flaps open to achieve the same. Was planning on doing this prior purchasing any controller to see how it sounds etc..
    Sep 12 2022
    South Jersey
    Quote Originally Posted by brad65ford View Post
    Won't that trip a code?
    Sent from my SM-F721U using Audizine Forum mobile app
    May 30 2005
    fl
    Unfortunately yes you do get a check engine light since there needs to be positions that the valve stops at unless I made a bracket to duplicate the awe does It will blow a check light I actually did it today. It keeps the functionality still working it has no idea that there’s nothing there or nothing to rotating Personally, I do not like doing anything with these newer canbus Audi’s, they’re so sensitive. Only neg about this modification is you can’t put in to comfort quiet mode, but it’s easily reversible. Wired the valve forced closed so no rattling and mounted the valve offset to the stock mount so it could rotate as it would normally do. Pretty impressed how it came up. Will post pictures if anyone wants to duplicate. Also getting rear resonators cut out and straight piped. Did this before on one of the 8v Rs3’s I’ve had.
    Aug 02 2022
    South Carolina
    Just FYI when you do this and get the CEL, your ECU will pull power at higher RPMs it's been shown on other forums
    May 30 2005
    fl
    Quote Originally Posted by RScheiss3 View Post
    I thought so too since it did this on our C8 RS6, totally can feel the difference. Though I don't believe it did this on the 8Y rs3, felt the same. Usually I have an extremely sensitive butt dyno , no need to brake out the dragy I felt lol.
    Also if anyone does do this, it moves the valves actuators to a position you can't re-install so easily. Had to plug them in and let them go backwards while running, then up plug. Shut car off and quickly plug them in to which they started moving clockwise again. A little tricky to do but really the only way I could figure out since they can not be moved manually, assuming VCDS could do similar but didn't go that route. Long story short, the check engine went away after driving off thankfully.
    Need one of these, would be cool to see them offered somewhere as a item. You can see that there is a stop to one side, assuming that is when its at rest (open/clockwise position)
    Apr 17 2023
    Durban
    ASR valve control
    Can’t understand why you would do an extreme hardware mod for a valve control when it can be done with the asr or cete module.
    May 30 2005
    fl
    Honestly I don't, though regarding your not understanding why some people like to mod or alter things themselves at times when they have the ability to instead of purchasing something. I'm not sure how to help explain this any better.
    Apr 17 2023
    Durban
    ASR valve control
    4 months with the ASR and really enjoying it.
    Here is a soundclip
    Soundclip below
    https://streamable.com/te0gyj
    Jul 21 2014
    United States
    Otherwise stock? Sounds good.
    Apr 17 2023
    Durban
    Quote Originally Posted by GTItoS4 View Post
    Yes completely stock. No mid pipe or down pipe as this affects the maintenance plan and warranty the car has in my country
    Dec 18 2023
    Portland, OR
    I just installed the ASR controller and so far it feels worth it — it feels like the car should've come this way. Totally stock US car otherwise.
    Junior Member Two Rings TSoich's Avatar
    Apr 23 2018
    2004 S4 | 2024 RS3 | 2018 Q5
    Phoenix, AZ, USA
    The ASR CB2-SSA instructions still have this note:
    Series mode / workshop mode:
    The module is activated or deactivated via a key combination. When the module is deactivated, everything behaves as if no
    module were installed.
    Any idea what that means? And how to "... via a key combination"?
    Jul 15 2022
    US
    You can turn it on or off. When it's on you have the ability to open and close the valves when you want. When it's off it goes back to behaving exactly like oem, like you don't have a valve controller installed.
    Senior Member Three Rings Heat00's Avatar
    Oct 02 2018
    24 M2
    Florida
    Wow! That’s what I’m talking about ! You just cost me about 500$? lol. Wish we could just pull the fuse like on my bmw, free same result lol
    '24 RS3 (& '24 M2 sons car), '23 Scat Pack Widebody, '23 X3 M40i, '22 Charger Hellcat Widebody, '21 ScatPack Widebody, '19 Challenger 392 Widebody, '18 Audi SQ5, '18 Charger Daytona 392, '16 Charger Scat Pack, '15 Durrango RT, '14 Vovlo S60 R Rebel Blue, '12 Q5 2.0, '10 Mustang GT, '08 BMW E90 M3, '07 BMW E90 335i
    Oct 02 2018
    24 M2
    Florida
    Quote Originally Posted by grandpab View Post
    a link would be great if you have to a good place to buy... also hows the install? does this require ripping apart the dash or something lol...
    Senior Member Three Rings NapalmEnema's Avatar
    Jul 02 2022
    2022 Kyalami Green RS3
    Houston
    You're probably losing power though elminating the backpressure down low. While a sound 'negative' I don't want to do these things because of the loss of power in the low RPM's with that backpressure eliminated.
    2022 RS3 Kyalami Green
    2017 M2 Performance Edition - Arctic White
    2021 Type R - Shadow Grey Pearl
    Feb 03 2020
    Mind showing me where back pressure has EVER increased horsepower in any way?
    Jul 02 2022
    Houston
    Quote Originally Posted by Rguy View Post
    For small engine turbo cars I've experienced it first hand with my buddies Mitsubishi Evolution - when the backpressure was reduced low end power was sacrificed. Assumed that's why Audi does it with this car to get that extra bit out off the line / lower RPM with the same small engine turbo setup. Seems logical and why would they go to so much trouble when it should be simple - flap open - flap closed. Instead they went to all the trouble of tuning the car to open flaps various degrees depending on RPM and load. Seems that'd be the reason for it. Is the power loss fall on your face noticeable? Not excessively but I wager it's still present based on the above. I'm sure the sensation would be more noticeable with the completely gutless 2.0 Mitsubishi motor vs the 2.5 but feel it would still be there.
    Sep 12 2022
    South Jersey
    Don't lug the engine.
    Jul 02 2022
    Houston
    Quote Originally Posted by Jetdriver View Post
    Not in a lugging engine scenario bud - just normal driving off the line and such. No worries agree to disagree have a good one
    Senior Member Two Rings itr325's Avatar
    Mar 13 2007
    1998 Acura Integra Type-R
    Milwaukee/Wisconsin
    Are the only places to get the ASR controller form overseas? It's significantly cheaper than the CETE and does the same thing.
    Jul 15 2022
    US
    Quote Originally Posted by itr325 View Post
    If it's shipping you're worried about they're fast shippers. I ordered mine and it was only like 3 days later it arrived.
    Mar 13 2007
    Milwaukee/Wisconsin
    Nope, just didn't know if there were any dealers in the US.
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    This doesn't entirely seem to be the case when exchange, higher cost shipping and possible customs duty is factored in when comparing the CB2 to the CETE valve controllers. When all is said and done ordering through ASR (if you can get their website to work well) costs look essentially the same depending on the exchange when ordering.
    CETE 8V and 8Y RS3 valve controllers are in stock in the US and ready to go!
    Website Link: CETE Automotive A3, S3, RS3 8V | '14-'20 Products <-Click Link for More Information
    Website Link: CETE Automotive A3, S3, RS3 8Y | '21+ Products <-Click Link for More Information
    If anyone has any questions on the benefits of the CETE setup or needs further info feel free to email anytime: [email protected]
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Mar 13 2007
    Milwaukee/Wisconsin
    Quote Originally Posted by [email protected] View Post
    Cheers,
    466.97 shipped compared to $595.38....That's a sizable price difference for the exact same product.
    Aug 07 2008
    Dallas, TX
    ASR with 60Euro shipping via UPS with possible brokerage and customs duty costs it will likely come out to around the same pricing. Can't comment how they classify their product for export and how much UPS would charge for brokerage fees.
    The CETE standard valve controller is $550 and average shipping around $20 in the lower 48 states, so around $570. Sales tax only applies to purchases shipped to TX so that might be why your CETE price is a bit high, but sales tax would not apply to your listed location. No possible customs costs or brokerage fees plus 1-4 business days to all locations in the US.
    Cheers,
    www.europrice.us
    [email protected]
    Mar 13 2007
    Milwaukee/Wisconsin
    Cheers,
    Shipping is $48 and no tax no fees or duty, VAT included. Add the $20 for shipping and the CETE is now over $600. Not trying to start a war, just don't want to spend more for the same product.
    Jul 15 2022
    US
    Looks like ASR is $407 shipped right now.
    - - - Updated - - -
    I didn't have any additional fees.
    Mar 13 2007
    Milwaukee/Wisconsin
    - - - Updated - - -
    From where?
    Jul 15 2022
    US
    From where?
    Straight from ASR. https://asr-component.de/gb/audi/179...eft_hand_drive
    €391.93 shipped, should be $406.94 after being converted right?
