In the last week I'm getting the "Alternator Fault: Battery Not Charging" warning, but it is coming on intermittently. After start it comes on after a minute or so, but sometimes will disappear 3 or 4 minutes later, maybe reappearing 5-6 minutes after that. Or not. I had one drive where it was on for nearly a half hour. And the next drive it did not appear at all. (turned off all electrical I could when it came on)
Multimetered the battery and it is holding charge on it's own. Multimetered the battery when the warning light was off and it was in the 14.6V range as you want. Multimtered the battery when warning light was on after about 10 minutes and it was down to 11.5V and ticking down. So it seems that the alternator is definitely failing, but not 100%. I'm charging the battery back up when not in use.
This weekend I'll pull the clip off and test the connections at the back of the alternator, do a multimeter voltage drop test, and will pull the belts and see if there is any play in the pulley.
Any other suggestions? Will an alternator fail like this or does it just go down 100% and never comes back to life?
6 months ago I replaced the water pump and thermostat along with the belts, but not the tensioner. (170,000 km on the odometer)
Thanks, all.
