Reposting this in here since it got zero response in the main page...
Upgraded the fuel lines the other day and when starting it, especially after a long sit (days), there is loud noise that comes from the passenger rear area. I would describe it as a growl... akin to an old motor before the oil pressure picks up... that I located somewhere in the Rt Rear area.
Has anyone else that upgraded lines created odd noises from the fuel pump or lines? I figured the first time was the dry line pressurizing... and it was MUCH worse than the 2nd time. By the 4th or 5th start, it didn't do it at all.
Today after not driving it for 4 days, it did it for a second or two, about as long as normal chain rattle. It only does it on start up pump, not on pre-start pressures.
It is definitely fuel associated. I had the "vibrating" cross over line noise which I cured. I am wondering if it's common and if it's something similar to that from a line under that I just need to isolate a little better!
Till then, I'm keep an ear on it.
Cheers,
KS
