Results 1 to 7 of 7
    Feb 15 2016
    Cambridge,Ontario
    quick question about exhaust clamp
    My Sons A4 2.0T manual just ruptured the flex joint.. anyone know if its the 55mm by 95mm clamp or the 50mm by 95mm sleeve clamp for that car ?
    NM i found it
    for those looking in the future it is the 55mm by 95mm clamp .
    Doing this job is much easier if you drop the cat and flex pipe tigether, you need room under the car to do it but you undo the oxygen sensors, unbolt the cat from the tubo, undo the sleeve clamp , then unbolt the flex pipe retaining bolt .
    Then the whole assembly drops out.
    replace flex pipe and put in new gasket, between flex and cat, raise it back into place. put on new sleeve clamp , but retaining bolt back in, replace turbo to cat gasket , bolt turbo back up, put O2 sensors back in ... done
    tools to get that last turbo to cat bolt
    am i the only one that seems to have to do this every 4 years or so ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Every 4 yrs? Must be those harsh Ontario winters. Bought new in 2008 - just had my factory original flex pipe replaced Jan 2024 at around 224,000 km. It's had Revo Stage 1 since 5000 km, not that that should affect flex pipe life.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Feb 15 2016
    Cambridge,Ontario
    yeah tonnes of salt .. plus aftermarket ones are crap ... rust out fast. but just can't justify an Audi one. first one lasted 255k km now it's got 338 and I've put 2 in, needs a third lol
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Was gonna say, its like 2.125" OD, so 55mm.
    Sent from my LM-V600 using Audizine Forum mobile app
    Established Member Two Rings OGB7A4's Avatar
    Sep 06 2023
    2005.5 B7 A4 2.0T 6 MT QUATTRO
    MIAMI, FL
    Wondering if some type of shielding could be installed to prevent all the salt from directly hitting it.....
    Feb 15 2016
    Cambridge,Ontario
    or be built from less chineesium.. the first one lasted a long time .. the aftermarket ones are just poor quality , but it seems its 88 bucks or 1200 lol
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    in case anyone is planning for this project. the 3 bolts holding the flex joint downpipe to the cat are m8 35mm.
    1976 Yamaha XS 360
