So I went to another country for 3 months for family event and while I was away I left my car in the driveway for 3 months. Ever since i came back I’ve been having electrical issues like alarm going off randomly, rear defroster not working and worse of all is the radiator fan not running.
I already checked the ecu box I’ve replaced the ecu box it self two years ago and it was nice and dry.
For now I unplugged the alarm and just don’t use the rear defroster but the fan is getting little annoying as I can’t idle for too long without over heating.
I’ve applied direct 12v to FCM and the fun does not come on i don’t want to cut the wires to fans until i know it’s the control module or fan it self.
I also did output test with VCDS and fan did it come on. I would assume maybe the relay is bad but the fact that even after giving direct power fan didn’t come off now I’m certain it’s either fan control module or fan it self. In this case which one should I say is bad?
I also have code for lower coolant temperature sensor G83 I already have the new sensor and code P1672 coolant can’t control 1 - open or short to ground.
