in the final stages of getting my car back together - I had to manually walk back the e-brakes in the rear calipers due to low voltage from my battery dying while I wrapped my car - dont ask.
In taking those calipers off, I must've lost most of the brake fluid in the hard line. I successfully bled the rear passenger caliper, but can not get any fluid out of the line on the driver rear.
Took the caliper off and let the brake line hang, pressed brake pedal and it firmed up almost instantly. No fluid...
Went under the hood and cracked the rear driver abs module connection line, which I also found bone dry.
Is a solenoid stuck shut in the ABS module? I am thinking I need to pull the module and blow some alcohol through with some compressed air if i have a stuck valve.
No I dont have a vacuum pump but will go get one if that is the way to fix the issue.
Anyone have any solutions or ideas?
