Hey guys, apologies if there is already a thread for this, but from my searches I haven't found anything exactly the same as my issue.
Some background: my S3 is completely stock other than a resonator delete, I recently changed the spark plugs 10-15K Kms ago, and oil+filter change <5K Kms ago.
My problem: So to put it simply my car has a burbly/stuttering idle when the car has warmed up and I stop at a red light or even when in park. The car drives perfectly fine otherwise no noticable changes in performance or smoothness when moving. I have attached a video as this issue is pretty hard to describe obviously lol. The engine does seems to shake more aggressively in sync with the exhaust stuttering and has a bit of a constant shake but nothing super concerning. Oh also there is not change in the RPM so I'm pretty stumped as to what the hell is going on here.
I have checked my PCV, as I heard that it can cause similar rough idle if the vacuum seal is broken, but it seems to be fine as there is no pressure when I place my finger over the hole. I have also ruled out the spark plugs as I changed those very recently and they are just the OEM spec spark plugs, but I will take them out once it warms up in my area and visually check them.
I have OBD11 but I am not getting any faults that I believe would cause this, but I will attach some screenshots incase I am wrong. I do not have a check engine light either all my faults are intermittent.
I would also like to note that the stuttering has seemed to gotten more frequent over time(or maybe I just notice it more now) but they aren't exactly changing or getting more aggressive. In the cold weather they seem more prominent but that could just be me.
Any help with this would be great!
Thanks,
Jacob.
VIDEOS:
https://youtube.com/shorts/c1LPELbpS5s?feature=share
https://youtube.com/shorts/k5QkUMEnXYE?feature=share
https://youtube.com/shorts/NYowCszmLFM?feature=share
Fault Codes:
Attachment 323582Attachment 323583Attachment 323584
