Results 1 to 5 of 5
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Motor oil coming out of lower control arm front passenger side?
    After getting the tow when my motor seized the flatbed had a pool of oil directly underneath that side...not under transmission or motor.
    I jacked up the car and couldn't find anything, but some moisture....except dark oil identical to motor oil thinned out dripping from the main lower control arm bushing. He did anchor this chain and hook around it to pull it onto the flatbed.
    Is there oil in the bushings of the lower control arms now? I know the previous generations motor mounts had purple fluid in them. I've read our cars have oil in the motor mounts, but in the control arm bushings too???
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Does it look something like this?
    This is a very common failure/wear item on the B8. The photo is mine at 71K miles, one side was showing failure, replaced both. As you can see, they have black hydraulic fluid. I believe the motor mounts also have this type of fluid.
    The next thing to go on the front suspension will be the upper control arm bushings.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Mar 19 2014
    Quote Originally Posted by audrobotic View Post
    Yes, but the small puddle was big enough it seemed like an oil leak. I can't believe there's that much in there...it is a large bushing and even small amount of oil looks like a lot when it spills.
    Senior Member Three Rings WHT13AR's Avatar
    Oct 09 2022
    '07 GT500, '21 Silverado, '79 Mustang Coupe, 2015 Allroad, 2011 Avant (beater)
    Michigan
    Yeah, there's more than you think in there. Same thing just happened on my car. Changed those and in the process, noticed all the other dried out bushings. Few weeks later, replaced all the rest of the front suspension. Drives like new.
    Oh yeah, did the motor mounts a few months ago too. LH was leaking.
    Collecting rear suspension parts next.
    Sent from my KB2007 using Audizine Forum mobile app
    There are many like it but this one is mine... (Coming Soon) ;)
    Jul 16 2018
    Atlanta
    The large subframe bushing for the guide links (the lower curved arms) was originally a 65mm conventional bushing. But NVH complaints, apparently more so from NAR than RoW :-), led them to change it to a 75m hydraulic bushing starting MY10. Though not across the board, 65mm conventional was still used in RoW for a time, etc.
