I had it tuned right after I bought it, so I'm not sure if the problem was there before the tune, or as a result of the tune. But it's been going on for years. It wasn't happening that regularly before, but as of recently it has started to occur very regularly and these days I'm pretty much driving in limp mode most of the time.
The issue seems to relate to sensing the correct throttle pedal position. When EPC comes on, I need to depress the throttle pedal 80% of the way just to get going. Then all of a sudden the pedal travel might start working correctly again, and the car seems to enter a semi-limp mode: it will respond lively, but cap boost to 0.5 bar instead of the tune's 1.5 bar. Then after a while it might drop back to full limp mode and require almost full throttle just to get going. One morning it was so bad that full throttle was not increasing the RPM at all. I switched off, waited for an hour, then it was good again. The problem may occur in both open and closed-loop conditions, I haven't noticed any particular pattern that may trigger it. WOT does not make it go away.
When the EPC light does not come on, the car works really well and the ECU program is super smooth and responsive across the entire RPM range. Arguably one of the best tunes I've had in any of the cars I've owned before. The output is 350HP @ 1.5bar. The tune consists of ECU reprogramming, upgraded turbo, higher flow fuel pump, performance catalytic converter, and a few other things that are irrelevant to this discussion (clutch, suspension, etc).
I mention the upgraded cat because I can't remember if it retained the O2 sensor, and if it did, I don't know if it reads the same as in the original cat.
The Secondary Air Injection Solenoid Valve that comes up as "open circuit" in the ECU scan below, has been removed completely and it's not in use. I believe its purpose was to preheat the cat faster in order to reduce emissions.
This is what I get from VCDS:
Code:
Friday,15,December,2023,14:24:47:62795 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels) VCDS Version 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4 Data version: 20231027 DS351.0 www.Ross-Tech.com -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 06A-906-032-APX.clb Control Module Part Number: 8L0 906 018 K Component and/or Version: 1.8L R4/5VT 0005 Software Coding: 05610 Work Shop Code: WSC 66565 VCID: 372A2C214652D002DE9-5161 5 Faults Found: 17840 - Secondary Air Injection Solenoid Valve (N112) P1432 - 35-00 - Open Circuit 18038 - Accelerator Position Sensor (G79) P1630 - 35-10 - Signal too Low - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - Intermittent 17796 - Control Module Malfunction - DBW Throttle Monitoring P1388 - 35-10 - - Intermittent Readiness: 0000 0000
Anyway, back to the more important problem, I remember a few years back right after getting the car from the tuner and telling them about the intermittent EPC issue, they took it back for inspection. They told me that they changed the Accelerator Position Sensor. I hope they did, but I can't be sure: as I was driving out of their shop, the EPC lit up again. They were pulling their hair out. However they couldn't think what else to check so they made me take the car away anyway.
This past weekend I fired up VCDS to check what throttle pedal angle the ECU is seeing (Function 08, Display Group 062). I ran the test when the car was in the severe limp mode condition, requiring almost full throttle to get going. This is a short clip of the result:
The manual says values in Zone 3 should always be about twice as high as those in Zone 4. In other words, it should look like the chart on the left. However if I plot the values from my video above (see chart on the right), the chart looks all wrong. The values do increase gradually, but at a different rate. In my case Zone 4 starts higher, and around half the pedal travel they switch and Zone 3 becomes higher!? Also at fully depressed pedal, the ECU thinks I'm 49% there.
After seeing this I thought to do a Throttle Adaptation, however sometimes the car gets into a less severe limp mode (see above) or even at no limp mode at all, in which case the throttle responds correctly. So it seems the problem is elsewhere, something is intermittent. Also adapting the throttle to the condition above will probably be dangerous when out of limp mode, as in that case the adapted settings will result in WOT at half the pedal travel.
Checking the voltage at the throttle pedal connector gives me the expected values as per manual:
Code:
Terminal 1 to ground = ~ 5v Terminal 1 to terminal 5 = ~ 5v Terminal 2 to ground = ~ 5v Terminal 2 to terminal 3 = ~ 5v
Connect test box V.A.G 1598/31 to wiring harness for engine control unit. Do not connect to the engine control unit itself. => Page 24-16
Yesterday I tried another mechanic. They changed the battery to a new one, cleaned the throttle body and reset it, cleaned the MAF sensor. Obviously that didn't help. I performed another VCDS AutoScan after I got the car back and noticed some new weird codes, including a P1609 Crash Shut-Down Activated, even though no crash took place.
Code:
Address 01: Engine Labels: 06A-906-032-APX.clb Part No: 8L0 906 018 K Component: 1.8L R4/5VT 0005 Coding: 05610 Shop #: WSC 66565 VCID: 372A2C214652D002DE9-5161 6 Faults Found: 17840 - Secondary Air Injection Solenoid Valve (N112) P1432 - 35-00 - Open Circuit 18017 - Crash Shut-Down Activated P1609 - 35-00 - 18010 - Power Supply Terminal 30 P1602 - 35-10 - Voltage too Low - Intermittent 16885 - Vehicle Speed Sensor P0501 - 35-10 - Implausible Signal - Intermittent 18038 - Accelerator Position Sensor (G79) P1630 - 35-00 - Signal too Low 16486 - Mass Air Flow Sensor (G70) P0102 - 35-10 - Signal too Low - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8N0-907-379-MK20.lbl Part No: 8N0 907 379 C Component: ABS/EDS 20 IE CAN V003 Coding: 13504 Shop #: WSC 06435 VCID: 3C20330D7F74F35A33B-4B1F No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl Part No: 8L0 820 043 M Component: A3 KLIMAVOLLAUTOMAT_D77 Coding: 03141 Shop #: WSC 06313 VCID: 323C1D35AD30352AE97-25A7 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8L0-959-655-AI8.lbl Part No: 8L0 959 655 G Component: Airbag Front+Seite 1007 Coding: 01104 Shop #: WSC 00001 VCID: 42DC4DF51D9085AA797-5161 1 Fault Found: 65535 - Internal Control Module Memory Error 00-10 - - - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8L0-920-xxx-17.lbl Part No: 8L0 920 980 B Component: AB-KOMBIINSTR. VDO D05 Coding: 01444 Shop #: WSC 00428 VCID: 323C1D35AD30352AE97-5161 Component: AUZ7Z0X1122827 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1122827 1 Fault Found: 01176 - Key 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 22: AWD Labels: 02D-900-554.lbl Part No: 02D 900 554 B Component: HALDEX LSC ECC 0006 VCID: 1F1AE481CEA28842369-4B1F 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 8D0-862-257.clb Part No: 8L0 862 257 P Component: CV-Pump, Alarm, RC D13 Coding: 13130 Shop #: WSC 00000 VCID: 42DC4DF51D9085AA797-4F0D 2 Faults Found: 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01134 - Alarm Horn (H12) 49-00 - No Communications ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 00000 VCID: 6098A77DB35CF7BA4F3-4AC3 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00002 Shop #: WSC 06313 VCID: 6596B669AC7E9292BC5-5185 No fault code found. End----------(Elapsed Time: 03:10, VBatt start/end: 12.0V/12.2V)-----------
I'm pretty stuck, any help will be greatly appreciated.
