Results 1 to 9 of 9
    Junior Member One Ring
    Jan 22 2021
    Colorado
    Why replace upper control arms instead of just bushings?
    Hello-
    I have a 2015 S5 with 72k miles. An indi shop recommends changing my upper control arm bushings (both sides) and wants about $900. This is just for replacement of bushings, not the arms themselves. A couple of questions:
    1. Is this about the going rate for this work?
    2. Why do people replace the ENTIRE control arm instead of just the bushings? Is there another part of the control arm thay gets worn out, other than the bushings?
    The car drives straight as an arrow with no play in the steering, bit photos of the bushings appear to show wear.
    Thanks for any thoughts in advance!
    May 20 2010
    Quote Originally Posted by brookiez28 View Post
    Hello-
    If the bushings have cracking, they should be replaced. That rate seems a bit high to me; that said, I don't think you can R&R the uppers with the strut in the car, so that added complexity does not help. I had all the front control arms and outer tie rods on both sides of my A6 replaced last year for a bit more than that in labor. The labor to press out/in a bushing is definitely longer than the time to swap a whole arm, but a bushing is a lot cheaper than a whole arm.
    The ball joints at the other end of the control arm can wear over time. If the boots are torn, it may be wise to change them because dirt can get in.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jan 22 2021
    Colorado
    Good input. Thanks much, Audibot.
    Sep 17 2005
    Fremont, California
    Hello-
    The reason the full arm replacements are more common on the Audi platforms is due to the fact that there can be casting differences between various versions of control arm, causing press-in bushings to not always sit so nicely in the OE casting.
    034 arms are covered by a lifetime warranty through a few dealers of ours as well;
    https://www.ecstuning.com/b-034motor...-401-1042~034/
    -Sean@034
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    And the fact that upper control arms are the cheap ones. You should be able to get a set of all 4, 2 each side, for $200~$300 (TRW or Lemforder OEM producers) or $265 for 034 which will probably last you much longerthan OEM. They can be replaced without removing the strut, Wheel off, car jacked in the air or on a lift no problem. Alignment is recommended when you do it or soon thereafter as minor control arm variations in length can cause minor misalignment.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    I recently replaced my uppers and lowers with 034. Most of the bushing on the passenger side had cracked and some in the lower driver's side.
    The cost differential to replace the control arms versus replacing the brushing wasn't huge per control arm.
    Sent from my Pixel 8 Pro using Tapatalk
    Jan 22 2021
    Colorado
    Thank you, Sean.
    Jan 22 2021
    Colorado
    Thanks hahnmgh63
    Jan 22 2021
    Colorado
    Thanks Mrads. Just bought 035 50 duro engine mounts and will install in a few weeks. Will look at their control arms
