Hi all,
Recently, I tuned my A6 C7.5 3.0T Stage 1 (ECU+ TCU) from Jackal Motorsports, and I'll confirm that the car feels ALIVE! I love it so far, that I'm going to Stage 2 Single Pulley (SC pulley 57mm from CTS Turbo) because, why not? The upgrade is free. Now my question is this: What would you guys install for optimal performance when I go stage 2? I have done lots of research, yes. My engine's health is in great condition. Piston compressions are within value; good injectors; a perfectly clean throttle body, thermostat is good, water pump is good, no leaks or mixings, PCV seems to perform fine; every single fluid changed 3 months ago; 4 months oil change interval, drivetrain mount inserts (trans + diff), 034 motorsports density line mounts, sway bars etc. Solenoids recently changed, entire system is bled (no vacuum), brand new NGK 2669 BKR9EIX (gapped to 0.028", they run colder), etc. Mind you, I do 90% of the services myself because I have access to a full garage with all the tools necessary. I know, so lucky!
Where I live, it's very cold, and won't change until March - April or even May, so I can hold on from getting a merc racing HX paired with either cwa100 or cwa150 for NOW. I will not be pushing the car a lot until I have better cooling options. If im not gonna push, why go stage 2 you might think? Because it's free. Cold air intake is in my wish-list but I'm looking for something more of value. I did a few tests with a CAI on my friends A6 (stage 2 sp) and we didn't really notice a HUGE difference in CFM or temps. Maybe downpipes to eliminate some back pressure. JBX driveshaft carrier is good, but heard a few NVH concerns (i don't really care)
I just want to know what you guys would purchase to keep up with the performance of stage 2 sp. My budget right now is ~550-600$ (besides a hx, cwa150 or CAI). Tell me your ideas. Once i get better cooling, i might get a 179 or 187mm crank pulley (common failure).
