    Jan 27 2024
    England
    Exclamation S4 - Possible Wiring Fault (Codes: P0014, P12A3, P0366)
    Hello, I posted a few days ago to a Facebook group asking about advice about an issue with my car.
    I am looking to build a list of possible things to look into/inform a garage as a starting point to my possible errors.
    Faults on dash and fault codes (with info) from 034 App:
    • 26474 [P0014] B CAMSHAFT POSITION (BANK1) TIMING OVER-ADVANCED OR SYSTEM PERFORMANCE
    • 17895 [P12A3] FUEL RAIL PUMP CONTROL VALVE STUCK OPEN
    • 4511 [P0366] CAMSHAFT POS.SENSOR "B" CIRC. (BANK 1) RANGE PERFORMANCE
    Screenshots (Dash faults and Fault codes 034 app)
    https://imgur.com/a/UXMVe1T
    FB Suggestions:
    • Cam positioning sensor
    • Fuel pressure sensor / wire
    • Pcv pipe
    • Fuel rail harness
    • Some wire exposed/melted
    VCDS:
    Code:
    Address 01: Engine (J623-CWGD)       Labels:. 07K-907-309-V1.clb
    4511 - Camshaft Position Sensor B Bank 1 (G300)
              P0366 00 [01100000] - Implausible Signal
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 131680 km
                        Date: 2000.00.00
                        Time: 00:00:00
                        Engine RPM: 1901.00 /min
                        Normed load value: 16.5 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 39 °C
                        Ambient air pressure: 1020 mbar
                        Voltage terminal 30: 11.540 V
                        Unlearning counter according OBD: 40
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    26474 - Bank 1: Camshaft B (Exhaust)
              P0014 00 [11101101] - Retard Setpoint not Reached (Over-Advanced)
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 131664 km
                        Date: 2024.01.26
                        Time: 08:03:57
                        Engine RPM: 1052.00 /min
                        Normed load value: 7.1 %
                        Vehicle speed: 7 km/h
                        Coolant temperature: 70 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 14.900 V
    17895 - Valve for High-Pressure Fuel Pump
              P12A3 00 [11101000] - Stuck Open
              MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 131664 km
                        Date: 2024.01.26
                        Time: 08:03:37
                        Engine RPM: 956.50 /min
                        Normed load value: 9.0 %
                        Vehicle speed: 5 km/h
                        Coolant temperature: 68 °C
                        Intake air temperature: 22 °C
                        Voltage terminal 30: 14.700 V
    Unrelated but also flagged:
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
    328003 - Motor for Recirculation Flap
              B1092 07 [00001001] - Mechanical Failure
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 8
                        Mileage: 131665 km
                        Date: 2024.01.26
                        Time: 08:04:55
                        Recirc. air flap motor: spec.value: 11900
                        Recirculation air flap motor: actual value: 10007
                        System run time-Engine running time: 92 s
                        System run time-Terminal 15 on: 142 s
                        Recirculation air flap motor: diagnostic-Last operating state: No routine started
                        Recirculation air flap motor: diagnostic-Operating condition: Blocking handling
                        Voltage terminal 30: 14.78 V
                        Outside temperature: 8.00 °C
    Just looking to see if anyone else has any suggestions for things to look/check.
    Here is a screenshot of my log for reference:
    TIA
    Jan 26 2019
    When I first got my ‘19, I had a similar issue.
    It had only 1500 miles that I put on since new, and had the same issue on start up. But would go away after a restart.
    It ended up being the exhaust cam actuator. Faulty from the factory. They couldn’t figure it out at first, but almost 3 weeks of trying to figure it out at the dealer, they finally did. And it’s been fine since then.
    Hope this helps narrow the problem for you
    Jan 27 2024
    England
    Quote Originally Posted by Esmin23 View Post
    Thank you I will take a look into this.
    Jul 16 2018
    Atlanta
    So CWGD engine, EA839 3.0T. Bank 1 exhaust VVT and the HPFP. AVS (VVL) is on the intake cam, and not on the exhaust cam. VVT is on both cams. Just so happens the HPFP is driven by the bank 1 exhaust cam. Could be a problem managing the bank 1 exhaust cam is creating a problem managing the HPFP, which might be coming across as that error condition.
    P12A3 is not documented in the workshop manual. P0014 is, sort of. Whoever is writing these manuals these days needs to be given some other task back at Audi. Seems to be saying actual differs from specified by at least 3° for at least 1.5-2.0 seconds. Your graph clearly supports that error trigger based on those data values. The two items to eval are the G300 B1E cam position sensor and the N318 B1E VVT actuator. I'd probably be looking at the VVT actuator first. Almost like it has no control, just full off and full on. But you don't have any DTC for the electrical management of the N319.
    You don't provide a model year, so going to assume B9.0 (GP0). https://www.ilcats.ru/audi/?function...18&language=en
    So you see it's an assembly of three items: solenoid (magnet) [27], control valve [26], and vane adjuster [24 for exhaust, 23 for intake]. The solenoid and control valve are the same for all four cams, the actuator is the same for both exhaust cams (but not the same as for the intake cams). So you could swap the actuator with the B2E, then the valve with either intake cam, and the solenoid with the other intake cam. Then see to which cam the error condition moves.
    Or just assume you're in the same boat Esmin was in and replace the adjuster unit.
    Jan 27 2024
    England
    Thank you, that is great knowledge to know.
    I will be giving my Audi S4 2018 B9 to my local mechanic to investigate the issue. You think it’s safe to rule out a wiring fault? I couldn’t see any issues where people had mentioned.
    Any extra tips I can forward to him, to help or things to check for.
    Appreciate your help.
