Originally Posted by
mrdouble99
prety sure you can remove the sensor w/o recovering the R134, there's a spring valve were you screw the sensor
If it's on a Schrader Valve... then yes... a set of quick hands can loose a minimal amount.
That pic above doesn't look like it has a depressor installed though, so I would verify that it is a self sealing system before attempting the removal!
Here is the difference between a depressor and non-depressor attachment!
I don't see it in that sensor! Sensors with depressors usually have an offset port. but the pic is dead on, so it should be there and 2D just doesn't translate!
Here is a standard transducer with depressor. Not an absolute... but depressors are usually used on systems where regular servicing is needed and not generally on a sensor where a faulty reading could cause the system issues. It is Audi though...
Attachment 323355
Be Careful!!
KS
