Thanks to the help of everyone who replied to my post and a few YouTube videos(they didn't really help, this one really helped though,
https://www.youtube.com/watch?v=AZRoLtQwsug&t=1413s) (Pictures are rotated to the left for some reason)
I was able to get the old broken connector off of the engine and the hose off of the heater core, then get the old broken pieces of the neck that were still inside of the hose and remove the "permanent" metal ring
Keep in mind that I did this without taking out anything except for moving the coolant expansion tank out of the way
It wasn't very easy, but once I got the clip up on the connector, I used a small pry bar to push it off of where it connected to, after a little bit of pushing and making sure not to break anything it eventually came out
Then to get the hose off of the heater core, I used pliers to grab the hose on the part where the heater core was not(so like a little bit more down the hose so that I was not touching the neck of the heater core)
With using the pliers and a 90-degree pick tool I would pull on the hose with the pliers and use the pick tool to pull the hose at the same time(some WD-40 may help)
With some twisting and pulling it finally came off and I just pulled the hose up through the grommet
Then to get the metal ring off, I used pliers to basically pinch the metal ring and then rotate 90 degrees and do the same thing and I would keep doing that until it created a little gap to get my pick under it and then just pull it completely off of the hose
Also by doing that, it got all of the old broken neck that was still in the hose loose enough to where it would just fall out of the hose
Then with the new connector, I slipped it into the hose and put on a universal hose clamp from AutoZone to the hose in replacement of the "permanent" metal ring(wish I had taken a picture before I put it back in)
To put it all back in was not easy either it took a lot of finesse with the grommet
I pulled the grommet up out of the hole where it sits enough to where I could fit the hose with the new connector down through the hole and then connected it back on to wherever it connected to and pushed the retaining clip in
Then put the hose back onto the heater core and readjust the hose clamp back to where it was before
