Here's the charts from my spreadsheets that I use to calculate the limit from each part of the fuel system (Injectors, HPFP and LPFP). This is with 8P S3 injectors using stock S3 injector calibration, a stock HPFP (running stock rail pressure - 110 bar), and a stock LPFP using a B8 S4 LPFP controller (does the exact same thing as the B7 RS4 LPFP controller but you can find them for $50 used... I use B8 S4 LPFP controllers on all my B7 2.0T and 3.2 FSI builds).
This is the stock S3 injection window:
The rail pressure and lambda target I'm using:
Here is the power limit from the S3 injectors using stock S3 calibration (the injection window can be increased if more HP is needed... not necessary for a K04 though):
This is the power limit from the stock HPFP. The stock HPFP volume is 251 mm^3 and efficiency is 80%:
This is the limit of the stock LPFP with B8 LPFP controller:
And this is the combined limit of all the fuel system components:
Here's a comparison to the last K04 B7 A4 I did. The results were taken 6,000 ft above sea level so these numbers are going to look quite a bit lower than most. It peaked at about 21.5 psi of gauge pressure:
