I've been on here for quite some time, been in the Audi family since 2011 when I purchased my cactus B5 S4 6-speed as a young and eager 22 year old college grad.
This thread will be living/breathing as updates and mods are completed on my B8 S4.
A little bit about my S4...
- Purchased in Dec 2016 from Audi St Paul MN
- 66k miles; Brilliant Black; 6-speed+ sport diff; Premium Plus; alu optic exterior package
Within the first month of ownership:
- CTS Supercharger pulley 57.3mm
- EPL Stage 2 tune
- AWE Touring Exhaust + Diamond black tips
- Roc-Euro Intake
I drove the car ~80k miles with these mods up until July 2023, when I started having issues getting the car to go into gear. I had just moved from MN to southern California and was forced to ditch my shop, tools, and garage space. Not good timing for the b8 to start needing things...
I had no choice really, car had 144k miles on factory clutch. What a run, given 80k of those miles were stage 2.. I ended up forking 5500$ for a clutch replacement along with some suspension components (upper CA *4 + struts) to an indy shop in Encinitas CA. It was also time for tires, so Michelin PS4s went on the factory peelers.
Two weeks later, while casually driving down the coast, my center driveshaft support bearing blew. Called AAA for a tow home and the car sat. I knew about the JXB kit and this being a relatively low cost solution, however I was still irked by the huge clutch bill and started asking myself if it was time to get rid of the car. I ran some numbers and decided to start searching for my next vehicle. Took me a while to find the one, but I purchased a b9 rs5 sportback with 8k miles on the odometer - fully loaded, and had it shipped to me, so the b8 continued to sit as I had lost all desire to fix it. I was certain I was going to dump it.
Ended up taking a sweet job opportunity and needed to move to norcal in Q4 2023. This meant I needed to either sell the s4 before I left socal, or bring it with me. After running some numbers and looking at how much I could actually get for the car as it sat, I couldn't stomach it. I had to get it back on the road and take it with me. After all, it wouldn't be the worst thing in the world to have a daily driver to keep the rs5 nice and minty at all times....
I went back to the indy shop and had them install the jxb kit
One week after that, my water pump blew.
So I went back again for a full cooling refresh. crossover pipe + hoses + water pump + t stat (PCV done at 110k), and added on a couple more mods since I was now pot committed...
- 034 fuel pump piston upgrade
- E40 tune
- APR Carbon intake + carbon back tube
Car was finally mechanically sorted and in really solid shape to take north to my new digs. Once I got up here, the s4 didn't get much love. It had to sit outside in the driveway after I added a B9 Q5 prestige to the stable for the gf to drive. Didn't make sense to leave a new q5 outside in place of a 152k miles b8 s4 with crappy black paint that is impossible to keep minty... so I started losing pride in the car again. The water spots accumulated over the first couple months of sitting outside, and the paint really bugged me. I was back in the same "do I sell it now?" situation I was in before, only this time, I had 8000$ more money into it with almost 0$ increase in value.
So what do I do? The most financially responsible option possible, spend more money!!!
As the holiday break approached, I knew I needed a project. Boredom and I dont get along. Having never wrapped a thing in my life, I thought it'd be a great idea to take on wrapping my car. I always regretted choosing a black car. I purchased a 5x75' roll of Gloss Storm Gray (3M) vinyl to wrap the B8. This project scope quickly snowballed. "If I'm going to take off the wheels and bumpers" turned into about 6000$ of spend in parts. I am still in progress with the project, but thought I'd pause here and start a thread.
The car wrap is done, with the exception of the roof, which I will do once the car is back on wheels and the roof is a better working height. I have to say, I impressed myself with this vinyl stuff. It is totally doable if you are patient! It's definitely not perfect, but it looks really really good. I basically took the car from a 10 footer to a 1 footer. I will post photos soon.
Current list for project:
Bilstein B8 Struts
H&R Sport Springs
Inner + Outer Tie Rods - Meyle HD
Zimmerman Z Coat Drilled Rotors (front and rear)
Akebono Euro Ceramic Pads
APR High Output ignition coils
NGK Iridium BKR8EIX
Cam Follower + Fuel Pump O-ring (small leak)
AC Condenser (TYC)
Radiator (nissens)
CTS Heat Exchange upgrade
ECS Carbon Fiber Rear Diffuser
ECS Carbon Fiber side blades
Deval Carbon Fiber front lip
Carbon Mirror Caps (amazon LOL 99$ and you can tell)
Custom S4 badgery
Honeycomb grills (foggys too)
New AWE Exhaust tips Diamond Black
Aodhan AFF7 19x8.5 ET35 Matte Bronze
Cheers!
Dwight
