Results 1 to 2 of 2
    Feb 09 2013
    Southern California
    1999 Audi B5 A4 Avant Quattro 1.8T AEB Stage 3
    Hi Y'all, I have a 99 prefacelift(but I converted the headlights and fenders to facelift) a4 avant that I made into an 034 stage 3 build (GT28RS). It may not be 1000% stage 3(stage 1 clutch), I'm not certain, but that's what the Turbo is rated for and I installed a bunch of supporting parts too. I blew the engine two years ago, and it's been sitting at a mechanic waiting for parts until yesterday when they called to say they finally have all the parts and can do the swap. I'm swapping it for the same 1.8T AEB engine.
    I want to fix it and sell it. The quote to fix it is ~$7500. I'm looking to see if anyone would be interested in buying it either before or after the engine replacement and what you'd be willing to pay. Do y'all think it's worth $7500 with a new or rebuilt engine and all these parts? The car is in Austin, Texas. I don't have a ton of pictures at the moment, but here's the parts list.
    From 034 Motorsport:
    Tune, 1.8T, AEB, Big Turbo
    Turbo Kit, 1.8T Quattro GT28RS
    Bosch 550cc EV14 Fuel Injectors
    High Flow Racing Catalytic Converter, B5 & B6 Audi A4 1.8T
    AEM 320 LPH IN TANK Fuel Pump
    Turbo Inlet Hose, 2.5" Silicone, Longitudinal 1.8T for TT MAF
    HALLMAN PRO Manual Boost Controller
    Exhaust Manifold, High Flow Stock Fit, Longitudinal 1.8T
    Apikol Side Mount Intercooler
    Billet Diverter (Bypass) Valve Upgrade
    Boost Gauge on pillar
    From ECS Tuning:
    RA4 240mm Clutch Conversion Kit - Stage 1
    Milltek 2.75" Cat-Back Exhaust System - Resonated
    Coil Conversion & ICM Delete Kit With Red 2.0T Coils
    When I put the parts in I replaced the engine mounts, cv joints, oil cooler... All recommended gaskets, bushings, self locking nuts, a bunch of sensors (crankshaft position, coolant temp, oxygen), etc.
    The parts have maybe 10,000 miles on them.
    Black 99 Prefacelift A4 1.8t quattro Avant. ECS RA4 clutch kit. New AEB 1.8t engine installed ~30k on it
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    These have been going for a good amount on cars and bids as of recent, do a search on there and compare condition to those and that should give you an idea.
    2013 S4 Imola Yellow / IE Stage 2 / ECS Supercharger Pulley / IE Intake / ECS HX / AWE Non Resonated Downpipes / AWE Touring Exhaust / Vogtland Coilovers / Rs4 Grill / Eurocode SS / Black Forest Shift Knob / BBS LM-R / Alcon BBK / S6 Rear Brakes
    1996 Golf Harlequin #10
