Hello, I’m about to buy a few things for the car, a little prep for the spring (backroads and hopefully some track days). I’m currently looking at this setup:
Suspension: KW V3, with H&R Damper Cancel Kit, I drive the car on RS Mode 99% of the time so I don’t really care about the adaptive damper, plus I was looking at the KW one and is not super reliable.
Swaybars: H&R. Front, 27mm with two adjustments (planning on running the soft setting); Rear, 25mm with only one adjustment.
Endlinks: This is where I’m troubled, I’ve been looking at 034, Neuspeed, and recently found out that IE has some too.
Anyone else running the setup? Which configuration did you ended up doing? How has it tuned out? Something you would replace?
