Recently I've developed a fairly mild grinding/crunching sound coming from the front axle and was wondering if anyone else has even encountered this. At first I thought something was stuck in the brakes but a recent pad and rotor swap didn't fix it. I then thought it was my almost-worn summer tires but switching to winter tires didn't fix it.
I also definitely hear humming that I was thinking could be a wheel bearing, but there's zero play. Could it still be a bad wheel bearing without any play?
The crunching/grinding is mild and can only be heard at low speeds if you listen for it, and the wheel bearing type sound increases significantly with speed.
Appreciate any input!
*Car is a 2018 S5 Sportback and the sounds developed a few months ago.
