Originally Posted by
PlayitLeo
I live in Wisconsin and it gets cold! My boyfriend wants me to let my Audi run for at least 15 minutes before we drive it anywhere.
I live in MN and it gets even colder! (but I have a garage so I'm a wimp .... I also have a remote starter for when I'm not in a garage ...)
Presumably you've parked outside and you need to clear the snow and scrape your windows. Let it warm up while you're doing that and then drive gently away.
I'm assuming you don't live next to a freeway ramp where you'll be asking the engine for higher output within seconds of pulling away.
Presumably you have a 2.0 turbo? Once you start driving the turbo will quickly heat the oil .. at idle it will take much longer to warm up.
PlayitLeo
He says he is the car guy and he would know, but cars are built different these days...Any words of advice?
You're right, cars are built differently. When I was young - i.e. 30+ years ago - we had to let our cars warm up longer to get the fueling right ... carburetors and big iron engine blocks took a while to warm up and the fuel would condense on the cold metal surfaces. Fuel injection and plastic intake manifolds changed that. Also, today's oil technology and metallurgy is vastly superior to what it was like in the olden days.
Some advice for your "Car Guy":
What kills these Audi engines are stretched timing chains and burning oil, regardless how long you let the engine warm up.
Both issues are likely preventable.
Tell him to get a VCDS and monitor the cam phaser - this will tell him when the chain has stretched too much and needs to be replaced. From what others have mentioned on this forum that's likely going to be need every 90k or so, but there is some variation (hence why it needs to be monitored). Timing chain replacement is about $1200 - but if it isn't done in time then it can destroy your engine.
The oil consumption is usually caused by Audi's stupid windowed piston ring design getting clogged with soot from the direct injection. Best way to prevent this is to change your oil often - like every 3k miles or so. Using FCPEuro.com you can get your oil changes down to about $25 - and with an extractor it'll take 30 minutes and no need to get under the vehicle.
If you're already adding oil there might be some good options using engine flushes - others have reported good results. If this is the case come back and search our forum or make a new post.
