Originally Posted by
sleepy_rs3
Thank you guys for sharing this, it seems like an awesome upgrade. Do you guys have any photos or can you provide some more info on the mount you had to make?
I just used a piece of cardboard to trace the hole in the rear deck and bolt locations then stenciled it onto a sheet of MDF. Then I used the stencil included with the subwoofer to cut another bit of MDF to layer on top.
Lotusland
Rock R2D4-10 Prime R2 DVC 4 ohm 250 RMS 500 peak $130 on Amazon - it pounds pretty good - brings the B&O to life - purchased the Noico 80 mill sound deadener for $35 and the roller wheels for $20 for install so for under $200 CAN $ your all set. I payed pre inflation pricing as I did this in 2021 for considerably less.
I'm surprised that subwoofer works in a free-air install. I originally tried a Kicker CompRT subwoofer that wasn't designated as free-air and it barely made any difference when I had it plugged in. That's why I switched to the Pioneer TS-A2500LS4.
cmains78
How terrible was it to pull the rear deck? Do the rear pillars need to come out? Any messing with airbags? I sound deadened the trunk lid from the bottom side, but that did nothing to help with an increase in bass. Looking for a drop-in to use with the factory amp just like the above pics! Thanks!
Super easy if you have some tips. I used the below video to figure out how to remove the pillars and rear deck. I can take everything out in a couple of minutes now. No messing with airbags.
