Results 1 to 3 of 3
    Jun 01 2017
    Denver
    2.0 TSFI multiple faults, VERY rough idle, and overheating exhaust. Advice?
    Hi, this isn't my vehicle, trying to help out a friend. Its a 2018 A4 2.0T ULTRA TFSI. The cars been parked and hasn't moved in around 8 months now from what they told me. The car has an extreme loss of power, and a VERY rough and unsteady idle. If I try to press the accelerator the car doesn't even let the engine rev, like it has some kind of limiter preventing it from accelerating at all. If I do press the pedal the idle actually becomes very steady and almost normal / smooth. There is a ton of warnings on the dashboard, including engine, drivers assistance, parking brake malfunction, among others. Exhaust has no smoke to indicate anything there, the coolant looks clear and non contaminated, top of the engine oil fill plug looks clear and normal, no foaming or anything like that. I have no way to check the engine oil level as they don't put dip sticks anymore and the MMI was refusing to show the level even after running for around 5 minutes.
    Here's where I think the problem could be, during the short duration I had the car running to do the OBDeleven scan I noticed the exhaust shielding get extremely hot to the point it started glowing red. This was in the location where the oxygen sensor / turbo wastegate is located. Almost as if the exhaust is being blocked from exiting the engine block and it just continues to heat up and up. Could this be a failed waste gate or turbo?
    Here's the OBDEleven full scan, I do have a HEX-NET from Rosstech, but because its the limited VIN version I didn't want to burn a vin use on this unless I decide to do the repairs for them so I opted for my OBDeleven for the time being.
    Full scan
    Control Units: 21
    Fault count: 31
    Control Units:
    08 Air Conditioning
    System description: Klima Zone 3
    Software number: 8W0820043T
    Software version: 0210
    Hardware number: 8W0820043T
    Hardware version: H60
    Faults:
    No trouble codes found
    BC Rear Right Door
    System description: TSG HBFS
    Software number: 8W0959595H
    Software version: 0129
    Hardware number: 8W0959595F
    Hardware version: 005
    Faults:
    02 Transmission
    System description: 0CK 20TFSINAR
    Software number: 8W2927155AH
    Software version: 0002
    Hardware number: 0CJ927156
    Hardware version: H05
    Faults:
    09 Central Electrics
    System description: BCM1 MLBevo
    Software number: 8W0907063CB
    Software version: 0267
    Hardware number: 8W0907063BB
    Hardware version: H13
    Faults:
    81 Gear Shift
    System description: GSM-LL
    Software number: 8W1713041G
    Software version: 0077
    Hardware number: 8W1713041J
    Hardware version: H09
    Faults:
    BB Rear Left Door
    System description: TSG HFS
    Faults:
    5F Multimedia
    System description: MU-P-LNS-US
    Software number: 8W5035880D
    Software version: 1320
    Hardware number: 8W5035880
    Hardware version: 034
    Faults:
    42 Driver Door
    System description: TSG FS
    Software number: 8W0959593H
    Hardware number: 8W0959593F
    Faults:
    17 Dashboard
    System description: FBenUSA
    Software number: 8W5920890G
    Software version: 0377
    Hardware number: 8W5920890G
    Hardware version: H19
    Faults:
    16 Steering Column
    System description: Lenks.Modul
    Software number: 4M0907129GB
    Software version: 0009
    Hardware number: 4M0907129GB
    Hardware version: H11
    Faults:
    6C Rear View Camera
    System description: RVC Compact
    Software number: 4M0980556A
    Software version: 0250
    Hardware number: 4M0980556A
    Hardware version: H12
    Faults:
    A5 Driver Assistance
    System description: BVS
    Software number: 8W0907217C
    Software version: 0050
    Hardware number: 8W0907217C
    Hardware version: H17
    Faults:
    U112300 - Databus error value received
    static
    Priority - 6
    Malfunction frequency counter - 2
    Unlearning counter - 4
    km-Mileage - 84433 km
    Dynamic environmental data - 028D42028573
    date - 2023-10-09 17:58:07
    static
    Priority - 6
    Dynamic environmental data - 028D4302857C
    date - 2023-10-09 17:58:26
    static
    Priority - 6
    static
    Priority - 6
    Malfunction frequency counter - 3
    19 Gateway
    System description: Gateway
    Software number: 8W6907468F
    Software version: 0123
    Hardware number: 8W6907468E
    Hardware version: H43
    Faults:
    U140B00 - Energy management active
    Intermittent
    Priority - 6
    Malfunction frequency counter - 1
    Unlearning counter - 44
    Dynamic environmental data - 038A00002A13012A140000
    date - 2024-01-09 13:51:51
    U140500 - Terminal 15
    Implausible signal
    Intermittent
    Priority - 6
    Unlearning counter - 42
    km-Mileage - 84398 km
    date - 2023-10-07 17:21:41
    B191604 - Backup battery
    Faulty
    static
    Priority - 4
    Malfunction frequency counter - 76
    Unlearning counter - 255
    Dynamic environmental data - 2AD00000
    date - 2023-11-16 19:42:10
    46 Comfort System
    System description: BCM2 MLBevo
    Software number: 8W0907064EC
    Software version: 0387
    Hardware number: 8W0907064DC
    Hardware version: 025
    Faults:
    U112100 - Databus missing message
    Intermittent
    Priority - 6
    Malfunction frequency counter - 255
    km-Mileage - 36901 km
    Dynamic environmental data - 3A3E326C326C31FF175040040210028000000000009D009C01 00003C000100000001175500000000
    date - 2021-09-21 13:31:48
    44 Steering Assistance
    System description: EPS_MLBEVO_ZF
    Software number: 8W0909144H
    Software version: 0410
    Hardware number: 8W0909144B
    Hardware version: H08
    Faults:
    static
    Priority - 5
    Malfunction frequency counter - 17
    Dynamic environmental data - 4ED0252E630045000200017001528700000000000000000000 00000000000000000032
    15 Airbag
    System description: Airbag10.44
    Software number: 8W0959655G
    Software version: 0107
    Hardware number: 8W0959655G
    Faults:
    B13BCF2 - Multiple collision brake
    No function
    static
    Priority - 2
    date - 2023-10-09 17:58:22
    B101629 - Frt.pass. side airbag disabled indicator lamp
    Implausible signal
    Intermittent
    Priority - 2
    km-Mileage - 72693 km
    date - 2023-04-08 14:53:58
    01 Engine
    System description: R4 2.0l TFSI
    Software number: 8W0907115C
    Software version: 0006
    Hardware number: 06L907309
    Faults:
    P15A500 - Engine oil level check
    Implausible signal
    Intermittent
    P064200 - Sensor Reference Voltage "A" Circuit Low
    static
    Priority - 2
    Malfunction frequency counter - 35
    Engine speed - 0.00 1/min
    Normed load value - 0.0 %
    Vehicle speed - 0 km/h
    Coolant temperature - 33 °C
    Intake air temperature - 30 °C
    Ambient air pressure - 1010 mbar
    Voltage terminal 30 - 11.680 V
    Dynamic environmental data - 209628107A0011BD0BED3EFC0512160EC41514031770000067 DA10100000
    date - 2023-10-08 14:15:32
    P00B700 - Engine Coolant Flow Low/Performance
    Intermittent
    Priority - 2
    Malfunction frequency counter - 178
    km-Mileage - 83077 km
    Engine speed - 814.50 1/min
    Normed load value - 3.1 %
    Coolant temperature - 51 °C
    Intake air temperature - 29 °C
    Voltage terminal 30 - 13.000 V
    Dynamic environmental data - 209628441710F34418FFF8441A00004419029E441D4D2E441C 02B3
    date - 2023-09-16 16:59:30
    U061500 - Lost Communication With Engine Coolant Bypass Valve "A"
    Intermittent
    Priority - 2
    Malfunction frequency counter - 254
    km-Mileage - 83075 km
    Engine speed - 952.00 1/min
    Normed load value - 4.3 %
    Vehicle speed - 4 km/h
    Coolant temperature - 102 °C
    Intake air temperature - 56 °C
    Voltage terminal 30 - 12.800 V
    Dynamic environmental data - 209628441708464418085C441A000044191635441D4D2E441C 02B3
    date - 2023-09-15 20:49:39
    P202600 - EVAP Fuel Vapor Temperature Sensor Circuit Low Voltage
    Intermittent
    P255700 - Engine Coolant Level Sensor/Switch
    Circuit Range/Performance
    Intermittent
    Priority - 2
    Malfunction frequency counter - 11
    km-Mileage - 83293 km
    Engine speed - 822.50 1/min
    Normed load value - 3.5 %
    Vehicle speed - 1 km/h
    Coolant temperature - 68 °C
    Intake air temperature - 45 °C
    Voltage terminal 30 - 15.060 V
    Dynamic environmental data - 20961644170A8F44180000441A000044190000441D4D2E441C 02B3
    date - 2023-09-19 20:41:30
    P268100 - Engine Coolant Bypass Valve Control
    Circuit/Open
    Intermittent
    Priority - 2
    Malfunction frequency counter - 120
    km-Mileage - 81846 km
    Engine speed - 876.00 1/min
    Normed load value - 3.9 %
    Vehicle speed - 5 km/h
    Coolant temperature - 103 °C
    Intake air temperature - 51 °C
    Voltage terminal 30 - 12.840 V
    Dynamic environmental data - 20961B4417084644180876441A00004419166D441D4D2E441C 02B3
    date - 2023-08-12 16:20:56
    Intermittent
    P021900 - Engine Overspeed Condition
    Intermittent
    P201500 - Intake Manifold Runner Position Sensor/Switch Circuit
    Range/Performance
    Intermittent
    U013C00 - Lost Communication With Accelerator Pedal Module
    static
    Priority - 2
    Malfunction frequency counter - 4
    Coolant temperature - 27 °C
    Intake air temperature - 26 °C
    Voltage terminal 30 - 11.480 V
    Dynamic environmental data - 209628107A0011BD0BAB3EFC0512160FE715140317700001EE C610100000
    date - 2023-10-09 17:57:51
    03 Brakes
    System description: ESP9 Plus
    Software number: 8W0907379Q
    Software version: 0775
    Hardware number: 8W0907379J
    Hardware version: H10
    Faults:
    C105800 - Left rear tire
    Tire pressure warning - too low
    Intermittent
    C105B00 - Right rear tire
    Tire pressure warning - flat tire
    static
    Priority - 4
    km-Mileage - 77283 km
    --- - 8300001B892400000000
    date - 2023-06-03 20:21:27
    C105A00 - Right rear tire
    Intermittent
    U122600 - Implausible engine control module
    Intermittent
    Priority - 3
    --- - 74C00F00CA240050A080
    date - 2023-10-09 17:59:38
    U040100 - Invalid Data Received From ECM/PCM "A"
    static
    Priority - 3
    Malfunction frequency counter - 14
    --- - 73C00F00CA240000A080
    C105400 - Left front tire
    Intermittent
    C105600 - Right front tire
    static
    Priority - 6
    km-Mileage - 77918 km
    --- - 8200002A882400008080
    date - 2023-06-21 14:41:39
    52 Passenger Door
    System description: TSG BFS
    Software number: 8W0959592H
    Hardware number: 8W0959592F
    Faults:
    B122D29 - Lock unit for central locking
    Implausible signal
    static
    Priority - 5
    km-Mileage - 76385 km
    date - 2023-05-25 18:47:48
    B122B13 - Central locking motors
    Open circuit
    static
    Priority - 5
    Malfunction frequency counter - 34
    Unlearning counter - 140
    km-Mileage - 73154 km
    date - 2023-04-14 20:29:54
    Dec 10 2023
    Chile
    wow that is a lot of error
    Is the battery full charged? it was 8 months without charging
    Was the car las time running ok?
    Seems to be a communication error because of the too multiple error at multiple modules
    I would:
    -Fully charge batteries
    -Clear all codes after saving on a file
    -review engine and cables not to be rusted, with humidity or damaged by a mouse
    -review fluids level
    BDW review all the car in physycal conditions
    Then if is not ok, fix by parts, begining for the engine, then brakes, etc.
    And westgate works to avoid too pressure, at idle should not affect
    Jun 01 2017
    Denver
    Car was already like this prior to being parked for 8 months. It started doing this one day and they’ve left it ever since. I did ask if they ever had to jump the car or replace the battery at all before this happened to which they replied no. I asked that because of all the module faults and the energy management being active on multiple modules. The car had no issues starting up, battery was fine, brought a jumper pack with me for this reason but didn’t need to use it.
    I think something is going on with the evaporate system, from my limited knowledge… Something is causing the exhaust pipe (the one the O2 sensor screws into) to heat up extremely hot, very quickly, which is putting the car into limp mode.
